Results 1 to 4 of 4
Thread: A great garage in Limoges
  1. #1
    Join Date
    Oct 2009
    hampshire
    Posts
    528
    If you ever need a garage whilst in the Limoges area to say, read the fault codes on a failed servo unit and check the availably of a failed speedo sender unit () you could do far worse than 'BMW Adventure' just off the A20 in Limoges. It is a new place with basically every model in the BMW range in their showroom and English spoken. Their mechanic went over the bike to check a number of things and I got charged EUR 15 which I guess makes their labour rate about EUR 45-60 per hour.
  2. #2
    Senior Member
    Join Date
    Mar 2009
    Central Massif - France
    Posts
    499
    I concur though not as new as you think it has been there since 2007 I am friends with the owner and he will dig out blind to fix any problems you have on the spot! He will remove parts from his stock if necessary.
    When RiDE mag were over testing its big tourers amongst them was the GT1600 not many about at the time and an RT one of which was damaged due to a stationary drop, They had stripped off the parts from their still in the box bike without batting an eyelid.
    During the fuel filter and key ring antenna issues in the past they were happy to stock extra for visiting guests and leave them with us all we needed to do was provide Vin Numbers of bikes they were used on.
    And the coffee is great.
  3. #3
    Join Date
    Dec 2005
    Embra, Scotland
    Posts
    7,021
    Now there's a thought! A service at any BMW Motorrad dealer should be acceptable for warranty purposes NON? You can possibly see where my Caledonian genes are leading me ...
  4. #4
    Senior Member
    Join Date
    Mar 2009
    Posts
    499
    Click here to find out how to remove these ads
    If you are considering it, it is advisable to book as most BMW dealerships are few and far between and cover a large area.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
