r1d3rg652gs
Hello all ukgsers and Xchallengers!!!
I plan to replace my current beemer, a 2010 G650GS with a BMW G650 Xchallenge. Before I do so I have to sort out how to lower the bike. It will be done by customizing the seat and by fitting a hyperpro or wilbers rear shock.
So I need your guidance on some accessories for the part after the bike is lowered and ready to go.
1. X tank or Touratech auxiliary tank?
Does the X tank on the right side of the bike affect the handling? generally how has the auxiliary tank affected the handling of the bike?
Does the Touratech tank have to be removed for maintanance work (engine oil change, oil filter change etc)?
Does the rider have to fill both tanks seperately?
I guess the X tank is compatible only with soft panniers on the side, right?
Anything important one should notice before installing or choosing each tank?
2. Engine protection (skid plate and crashbars)
Which of the following solutions do you rate the most effective?
a. Bash plate with sw- motech crashbars (I think the SW-motech crashbars are not compatible with the TT auxiliary tank)
b. BMW crashbar
c. Touratech Skidplate (I think it's not compatible with any kind of crashbars)
3. Luggage...soft panniers or aluminum cases?
Magadan soft panniers vs Touratech hard cases.
Can the Xchallenge handle the hard cases from Touratech or other brands (actually are there any other option beside TT as far as hard panniers is concerned)?
Is the handling of the bike affected too much with the hard panniers?
What are the limitations of the soft magadan panniers?
Thank you all in advance. Any opinion from actual users is appreciated.
Any Do's or Don'ts are welcome...
b. BMW crashbar
