sanensafe
Have you thought of getting the standard shocks rebuilt.
Firefox (http://firefoxracing.co.uk/) do a postal service.
BWM std shocks are awful, the ESA variety is just awful and expensive
Mine has the ESA WP as standard and I’ve always thought it was one of the best features of the bike (2011 TB).
Always planned that if it went pop I would get Wilbers ESA just because I could go slightly lower but nothing a miss with the standard set up, yet.
Hi all, I'm in the same boat - tired ESA, bit of a budget, so was thinking of replacing the ESA with Wilbers (£710 pair) or Hagon (£600 pair) non-ESA. It's been asked a couple of times but no answer that I can see - will there be errors/fault codes if the ESA is unplugged (equiv to running non-ESA)? Thanks all!
2012 R1200GS Adventure
Seems it depends on the bike. Perhaps I’ll try to work out how to disconnect the esa and see what happens!
Fitting Wilbers shocks to ESA units will not replace the ESA stuff. The preload and damping control uses the same old stuff that came with the bike. If they are toast you will need new ESA at silly money or you could use the Tractive replacements from Holland. The company was set up by redundant employees when WP moved to Austria.
Wilbers also have WESA-X. The components look very much like those sold by Touratech for double the money. IIRC Tractive had a similar product but I cant see it on their website.
Tractive ESA replacement https://tractivesuspension.com/motorbikes/bmw-esa-products/
Wilbers WESA-X https://www.wilbers-shop.de/en/Moto...R12/shock-absorber-type-646-WESA-X.html?cur=5
