Hi All,
Just in case some of you might be involved in the technical side of broadband - I thought I would try here as Talk Talk have no idea
I am the last line from the exchange, and until recently had been able through TalkTalk, to get a stable 2/2.5mg download speed over the last few years. Recently they have put Fibre into our village as part of the rural broadband scheme, and TalkTalk offered an upgrade. They were confident of speeds of around 18mg, which I know compared to some of you is 'steam' powered, but for us would have meant a big improvement. I decided to go for the upgrade. I am just over 1 mile from the cabinet housing the fibre and it is copper from there.
On go live date, it was great I was getting 21/22mg steady as a rock. Then after a week they activated the TalkTalk TV which uses the broadband and Freeview ariel to run the system, this was free and part of my deal. Whether it was co-incidence or the causation, but since about the same time I have now got a very intermittent service which can vary from 22mg right down to 0.25mg. It keeps dropping out and has become unstable.
Interestingly at the same time when I do a speed test with OOKLA - it seems to think I am at a location, but not where I live!
It shows client location as somewhere near Eastbourne. It also tells me I am 1 mile from the Eastbourne server and 52 miles from London server and likewise all the distances from the various servers are incorrect. Finally, none of any location services will work when I am at home and connected to my WiFi, for instance, if I go onto Google Maps it will state unable to locate your position. If I go onto find my iPhone App, it will be able to see all of my devices, but will say 'online no location available'. Once I leave the home WiFi and go onto cellular or another wiFi connection they work fine!!
Often I will get error messages on the OOKLA speed test of 'intermittent Synch'.
TalkTalk have sent out an Open Reach engineer who spent 2.5 hours yesterday. The tests appeared to be OK, but to be absolutely sure he fitted the latest master socket with a radio interference shield, and also replaced the old cable from the socket to the telegraph pole, only as it was the old single wire type, putting the twin twisted wire to ensure reduction in any possible interference. When he had done this he saw a slight reduction in the resistance, but it was well within range beforehand. The engineer is confident that as copper wires go, that for that distance mine are in very good order and the problem lies with the ISP. TalkTalk can't seem to fathom this out.
The only other thing to mention is that as they rely on the TV Ariel as part of their system to work the TV side of things whether this is having an impact and causing these erroneous issues, as my TV ariel is pretty useless and I rely on a Sat Dish to pick up a decent signal
But it is causing a lot of frustration and like all of these types of issues will be something simple, but only known to someone in the trade who has encountered it beforehand. Anyone?
