Page 1 of 3 123 LastLast
Results 1 to 16 of 47
Thread: New build- from scratch onto a brick...PROJECT PLATFORM IS BORN
  1. #1
    Toubab Click here to find out how to Subscribe
    Join Date
    Apr 2003
    Secure unit 2
    Posts
    49,340
    THIS was our build on an 1100, which has now completed over 10k miles including the Nordkapp and the Elefant
    We've been threatening to do a build on a K bike, and here it is......
    (ongoing)
  2. #2
    Join Date
    Jul 2007
    nowhere inparticular
    Posts
    5,703
    excellent work that man
  3. #3
    Join Date
    Jun 2007
    Galway Ireland
    Posts
    4,179
    Love it, nice build I missed that first time around.
    I enjoyed viewing the build.
    Did you consider using box aluminium for the chassis?
    Lovely to weld if you have TIG.
  4. #4
    Join Date
    Apr 2003
    Secure unit 2
    Posts
    49,340
    Quote Originally Posted by patzx12 View Post
    No.......Box aluminium is bloody expensive, plus it's harder to fix if it gets crunched far from home.
    The K series one, like that 1100 build, is steel....heavy but cheap, easily fixed and easy to work with/on.
    Ok, so here we go....the brief for this customer's bike was for a strong, wide load carrying platform to go onto his brick.
    It won't ever have a chair fitted.....this guy just wants to use it for long distance heavy work like touring and winter rallies.....loading capacity and off road/ruggedness were higher on his list than aesthetics
    We also chatted about a split charge system, with the idea that a separate battery would run an LED floodlight on a telescopic pole for camping, would charge his gadgets on the camp site and would be isolated from the starting battery so he'd not pack up and find he couldn't start the bike after a week's camping.
    On a K bike, you need a subframe that mounts on both sides of the engine block but there's also onto a four point area underneath that's available.
    (Don't worry about the welding etc at this stage, it all gets tidied up and painted )
  5. #5
    Join Date
    Apr 2003
    Secure unit 2
    Posts
    49,340
    Now it's not perfect, but I think this is bloody nice
    And the rails mount on the other side in a similar fashion
  6. #6
    Join Date
    Apr 2003
    Secure unit 2
    Posts
    49,340
    The bike no longer needs a centre stand, and we KNOW that the centre stand mounting area is solid, so why not use it
  7. #7
    Join Date
    Jun 2006
    Islandmagee, Co Antrim NI
    Posts
    9,584
    I'm no "Engineer" (allegedly cos I as no letters after me name like!)
    But is that not a tad light on resistance to the "yaw" type forces Surely that is only the Sump held on by a dozen or so M6 bolts
    Edit Yup it is LINK M6 x 25 to be exact
    Here's a pic of a bought frame Bill most of the frames I have seen use the top forward engine mounts as locations
    Oh Great and Wise Deity, Grant me the serenity to accept the things I cannot change,
    Courage to change the things I can! And the wisdom to know the difference!
  8. #8
    Join Date
    Apr 2003
    Secure unit 2
    Posts
    49,340
    Quote Originally Posted by DrFarkoff View Post
    Patience
  9. #9
    Join Date
    Apr 2003
    Secure unit 2
    Posts
    49,340
    Ok, I'll jump ahead a wee bit
    (compare the acute angle on the left hand crossover rail in its first offering up to the angle we ended up with)
  10. #10
    Join Date
    Apr 2003
    Secure unit 2
    Posts
    49,340
    Rated at 5 tonnes
    Then on the back end, the final linkage (all are adjustable)
  11. #11
    Join Date
    Apr 2003
    Secure unit 2
    Posts
    49,340
    The deck frame is made of granite.
    Or Steel, I forget
    (and yes, that's scaffold tube )
    The cut-outs are for hooks BTW.....that worked on the GS rig quite nicely
  12. #12
    Join Date
    Apr 2003
    Secure unit 2
    Posts
    49,340
    The top front mounting point, tweaked, painted and ready to take the attachment rods
    And the left side view of the cradle, painted.
    We've only used red oxide paint, sanding and Wurth satin black spray so far in this build......powder coating is probably going to happen, but this is a cost-price to customer build and as such, it's also a test rig and learning set up as well......when we get a few more done and a couple of thousand K miles of hard real world use, the plan is to build different modular sections and powder coat them as standard, then mix and match them with custom storage/design/pods etc
    Yep, Thunderbird 2
  13. #13
    Old enough to know better Click here to find out how to Subscribe
    Join Date
    Jan 2009
    The nut behind the handlebars
    Posts
    1,075
    Bill,
    Looks good, but what about a little bit of triangulation between the 2 front tubes?
  14. #14
    Join Date
    Apr 2003
    Secure unit 2
    Posts
    49,340
    So the bike subframe is on, has been jumped up and down on by an (almost) infinite number of monkeys to show that if anything can go wrong, it will.
    The linkages from the subframe to the platform are on but just 'on', not tweaked or locked off, we can't do that until it's been around the fields for a couple of hours.....so next it's the suspension on the platform
    After a very brief experiment with various bits of old sidecar scrap we obtained for the last build, we settled on using a Ford Fiesta stub axle and arm....
    You can get a fiesta/focus stub axle from Ebay for under a tenner delivered, and they are available from pretty much any European scrap heaps 'just in case'.......they are reliable, well tested and bearings to fit are pocket money, standard sized (anywhere!) and so they make sense....plus, the one we fitted to my old Kalahari 1100 is properly tested out and has not been found to be lacking in any way, so we know they work
    If you look in the background of some of these pics, you may notice that Gert bought a stupidly enormous old stylee lathe (which he got for a conversely low price, as it weighs so frigging much that any potential buyer was looking at the equivalent of a Myford hobby lathe cost just to shift the fekker to a new location )
    Anyway, he's the guru on turning metal, and he made a prototype adaptor to go from the fiesta hub to a GS wheel.......the guy for this bike didn't want it though (it's a brick durrrrr) so the razther lovely hub adaptor will be used on the next build (already started) which will be a leading fork GS build, possibly (if we can get the parts at a 'price sensitive' level) 2WD with disc brake on outboard wheel
    So, unsurprisingly, this K rig will run on a standard Fiesta rim and tyre, which frankly is a good thing anyway given the price and availability (let alone longevity) of the hardware and rubber ( 13 inch rims will take 8 ply heavy duty trailer tyres ) around the world
    Swing arm pivot mock up being offered up onto frame:
  15. #15
    Join Date
    Apr 2003
    Secure unit 2
    Posts
    49,340
    Quote Originally Posted by NeilDD View Post
    Bill,
    Easily done, and will be if it 'feels' necessary IYKWIM
    I guess this is the beauty of a painted 'testrig' framework over a powder coated final product.....we had the whole suspension setup on and off the GS rig four times or more for total re-thinks as and when it didn't quite 'feel right'.
    If it needs 6 mill plate, we'll fillet in some 10 mill plate
    PS my gut feeling is that it won't need it.......look at the subframe again, but imagine a solid engine block connecting the lower 4 points through to the upper two points plus the upper left one, plus the sump plate.
    We're going to load this up with 40 stone of man beef and seriously abuse it, with accurate witness marks and even (horror of horrors!) a bullet cam watching things stress.....any doubt, and that angle will be filleted
    EDIT............Now you have me looking at it again, I suspect it'll be done anyway, git
  16. #16
    Join Date
    Apr 2003
    Secure unit 2
    Posts
    49,340
    It's nice having a chunky lathe.....
    Gert made up some bearing housings for the swing arm pivot........
Posting Permissions
  • You may not post replies
  • You may not edit your posts
