Page 2 of 3 FirstFirst 123 LastLast
Results 17 to 32 of 47
Thread: New build- from scratch onto a brick...PROJECT PLATFORM IS BORN
  1. #17
    Toubab Click here to find out how to Subscribe
    Join Date
    Apr 2003
    Secure unit 2
    Posts
    49,340
    and the swing arm was built up, with the Fiesta stub axle
    Bearings pressed in
  2. #18
    Join Date
    Jan 2014
    new milton New forest
    Posts
    827
    Keep going this is getting interesting now
  3. #19
    Join Date
    Apr 2003
    Secure unit 2
    Posts
    49,340
    Standard Fiesta rim with a slightly wider than base model tyre (possibly from a Fiesta S or something, I'm not sure) mounted up to the swing arm, with outer swing arm pivot tacked up for clearance checking.....
  4. #20
    Join Date
    Apr 2003
    Secure unit 2
    Posts
    49,340
    Suspension finalisation TBC, but for now, my old K100RS rear shocker was offered up together with an inexpensive bog standard trailer wheel arch to see how it all starts coming together.......Gert's satisfied
    Looking viable......
  5. #21
    Join Date
    Apr 2003
    Secure unit 2
    Posts
    49,340
    Lower suspension mount offered up
    (we like 'offering up'......if it looks good from all angles including standing right back and seeing if it looks like it'll track properly, it gets tacked up, then it gets wiggled, yanked uipon, bounced on, and the next stage is 'offered up' to make sure it'll all fit, then the previous stage's 'tacked up' status gets changed to properly welded up but not yet flap wheeled down or painted before the 40 stone of monkeys bounce on it to make sure it won't flex or bend in any way we don't like)
    It's not rust, it's 'workshop patina'
  6. #22
    Join Date
    Apr 2003
    Secure unit 2
    Posts
    49,340
    Next.....we obviously had to attach the top of the shock to the frame, so......
  7. #23
    Join Date
    Apr 2003
    Secure unit 2
    Posts
    49,340
    A bit more lathe work to make the mounting point.
    The positioning wasn't right, and considering the stresses this mount point would be subject to, we went for a strength upgrade (industrial stylee )
  8. #24
    Join Date
    Jun 2006
    Islandmagee, Co Antrim NI
    Posts
    9,585
    Pardon the profanity
    But Who da Fugg welded that back weld????
    I hope they are going to do it properly before it goes into service??
    Quote Originally Posted by Fanum View Post
    Edit thinking about it there's a right few dodgy welds .............. NEXT!!!
    Oh Great and Wise Deity, Grant me the serenity to accept the things I cannot change,
    Courage to change the things I can! And the wisdom to know the difference!
  9. #25
    Join Date
    Apr 2003
    Secure unit 2
    Posts
    49,340
    Quote Originally Posted by DrFarkoff View Post
    Untidy but strong
  10. #26
    Join Date
    Apr 2003
    Secure unit 2
    Posts
    49,340
    Checking for clearance......
    Weighted and unweighted, everything moves properly and there's no decrease in clearance, IE even on a hard corner fully laden, nothing's going to rub.
  11. #27
    Join Date
    Jun 2006
    Posts
    9,585
    Just going to say this once
    "Lack of Penetration"
    Ahem
    Coat Door outta here LOL
    Untidy but strong
  12. #28
    Join Date
    May 2004
    Wirral
    Posts
    14,804
    Fanum...do you not think that the sidecar shock top mounting plate would be much stronger if it was shaped (curved to suit) and welded inside the tube loop rather than stuck on the outside of it?
    Or at least,if external after all,welded around the curve rather than two edges.
    Also,the tube loop to frame welding points would benefit from some sort of triangulated gusset plates.
    Herr Smogbob's Number One
  13. #29
    Join Date
    Apr 2003
    Secure unit 2
    Posts
    49,340
    Ahem
    Quote Originally Posted by Tarka View Post
    Gert's using the rig at the moment to get back and forwards to the shed for a good shakedown......I'll be in there this week and will be taking along all of these points......it will be addressed
  14. #30
    Join Date
    Apr 2003
    Secure unit 2
    Posts
    49,340
    The mudguard mounting bar goes on, as well as a couple of lighting panels.....
  15. #31
    Join Date
    Apr 2003
    Secure unit 2
    Posts
    49,340
    LED markers from Durite's truck range for the front
    And the same on the middle of the outer side, just ahead of the swing arm for a bit of all-round visibility
  16. #32
    Join Date
    Apr 2003
    Secure unit 2
    Posts
    49,340
    Durite do these lamps in bulbed versions or superbright LED.....for cost reasons, these are the bulbed versions (it also means spare globes can be found pretty much anywhere...LEDs don't go wrong often but if they do and you don't have a complete replacement, you're into the realms of bodgery )
    A spray over and a tidy, plus a side facing repeater
    I have no idea where he found it, but Gert also came up with a rack to stick on top of the wheel arch........probably a good idea 'cos the first thing guaranteed to happen at a rally is some drunk knobber will try and sit on the plastic
Posting Permissions
  • You may not post replies
  • You may not edit your posts
