Page 2 of 5 FirstFirst 1234 ... LastLast
Results 17 to 32 of 65
Thread: SUNBEAM S8
  1. #17
    What a waste. Click here to find out how to Subscribe
    Join Date
    Oct 2003
    S/W London.
    Posts
    51,582
    Quote Originally Posted by The smudger View Post
    S
    I removed the plugs to check them, I honestly think the KLG one has some sort of historic value!!! I can remember when KLG head office was on Roehampton Vale, just past Kingston hill, now that was a long time ago. I am going to keep these as a reminder of how not to tune an engine, for goodness sakes they are even different plugs!!!
    The old KLG site is now an asda. They developed and made the spark plugs for the concord engines. No, don't ask me i haven't a clue.
    I've got a couple of brand new KLG plugs somewhere, my neighbours husband used to work for them and when he died and she cleaned out his shed she gave them to me for using on my bikes.
    Stewarts engineering used to be in Putney.
    All your BMW servicing needs at the .gsshop.biz, including 1200 models
    Recommended as an "excellent independant" in Ride magazine 2009.
  2. #18
    'Don't mess with me' Member
    Join Date
    Jun 2002
    Whitstabubble
    Posts
    20,218
    Thomas! There's a mouse duck in the house!
  3. #19
    Join Date
    Oct 2008
    Exmoor
    Posts
    500
    This looks like a wonderful project. Good luck.
    I liked the pic of your dog with his ball at his feet. "Dad's got a new bike so I suppose this is redundant for a while…." Great.
    Fluff.
  4. #20
    Join Date
    Sep 2012
    Torbay, England
    Posts
    26,882
    I had an old Pre Unit Triumph & did much the same as @BinRidin. Got fed up with leaks & things falling off so went Kawasaki.
    If I had another my first special tool would be a thread insert system. I prefer Timesert to Helicoil. Then use them everywhere.
    Loctite 518 anaerobic gasket is great stuff. Get a decent size tube and use with every gasket. Belt & braces.
    08 R1200GSA
    76 Suzuki GT750
  5. #21
    Join Date
    Oct 2014
    Collingham, England
    Posts
    117
    This looks really good to me. Always surprised by the genuine interest an old bike like this can create in all of us. I once owned a 500 Matchless, seeing this makes me yearn for another one. Best of luck with your project Smudge and please keep the updates coming
  6. #22
    Join Date
    Oct 2003
    Sunny Scarborough
    Posts
    4,509
    Calling 'The smudger'.......Sorry to be impatient, just wondering if She was up and running yet ?...
  7. #23
    Join Date
    Nov 2005
    Holt, Wiltshire
    Posts
    2,434
    Quote Originally Posted by jonnie comet View Post
    Not yet, cold evenings and busy weekends have kept me out of the garage...
    So far,
    New plugs, removed distributor and cleaned points, compression and cylinder leakage test, all OK.
    The wiring harness is vey poor, loads of bare wires... I have ordered a new harness (£50) and the plan is to stick it on this weekend, then i may be able to start it....
  8. #24
    Join Date
    Nov 2005
    Newbury, Berkshire
    Posts
    11,839
    Should we alert Wiltshire Fire Brigade just in case?
    2016 BMW R1200 GS Triple Black
    1980 Kawasaki Z1300
    2003 Sherco 250
    2002 Triumph Bonneville (Desert Sled)
    2017 Triumph Bonneville Bobber
    2003 Triumph Daytona 955i (Rob North Replica)
    2001 Yamaha T-Max Mk1
    1979 Yamaha XT500
  9. #25
    Join Date
    Nov 2005
    Holt, Wiltshire
    Posts
    2,434
    Heres the latest.
    It was such a lovely day today I just had to roll her out at do a bit of 'fettling'.
    I removed the Carburettor and managed to get the lower part off, replacing the gasket. I have now completely stripped the carb, new washers and a good clean up.
    Managed to get the cork (at least I think it was) around the frame spine where the wiring clips were. I'll fit the clips back using the foam Stewarts sent me.
    Here it is before,
    And after,
    So I then set about removing the harness. I took some good advice from some 'beam' experts, photographed all the closed in stuff before, removed the electrics box (it was filthy anyway), and removed the old harness. It was in a right old state, lots of bare wire, and but the look of a lot of it the bike had had an earth problem, lots of the insulation was brittle and melted...
    So I gave the boxes a good clean up and fitted the harness up in the house, the missus was out so I made good use of the kitchen table. I 'tinned' the bare wires with solder, and used Vaseline in the joints. It all went together quite well except I noticed there were 2 extra wires on the old harness, that were not on the new one.
    Heres a teaser for you all.
    On the back of the CVC I noticed there were 2 eyed connections apart from the 4 main ones. This looked odd as there were what looked like painted on letters. It looks like the coil on the right had an issue, and has been very rudely re-wound???
    I spoke to a mate as I couldn't understand what these 2 extra wires were. There was an extra switch on the bars, which discussing with him we thought that this was an addition to the charging system put in because there was a fault with it??? Looking at the switch it was connected to the generator light, you can see the connector in one of the pics below, so must have been some sort of switch in the charging system???
    On closer inspection the CVC has definately been 'interfered' with. There is something odd around the windings on the right, and these extra connectors have definately (albeit well) fitted as some sort of extra???
    Any thoughts anyone????
    I removed the distributor once more and cleaned up inside. I was surprised to find the baseplate came off really easily. I removed the points, condenser, and the baseplate screws, gently pulling the baseplate up from 2 sides it came off! All looked good inside, weights and springs cleaned up then rebuilt.
    I will resume tomorrow...
  10. #26
    Join Date
    Nov 2005
    Holt, Wiltshire
    Posts
    2,434
    Quote Originally Posted by Steptoe View Post
    Wasn't the old KLG building Art Deco???
  11. #27
    Join Date
    Aug 2007
    Braunton N Devon
    Posts
    292
    Sunbeam
    Hi Smudger. I've had a S8 since 1969 so I just about know my way around it now!!!!!!, any problems or advice drop me a line willing to help out.
    Barry G
    You're never alone with schizophrenia
  12. #28
    Join Date
    Sep 2005
    Ashbourne, Derbyshire
    Posts
    2,640
    Quote Originally Posted by Barry G View Post
    Barry G
    If I may also?
    Nick
  13. #29
    Join Date
    Aug 2007
    Braunton N Devon
    Posts
    292
    No worries Nick just drop me a PM anytime.
    Barry G
  14. #30
    Join Date
    Nov 2005
    Holt, Wiltshire
    Posts
    2,434
    Barry G
    Thanks Barry, dont suppose you have a spare 6v CVC regulator you want to sell? I need one! I can buy one from Holdens for 36 quid, but thought id ask here first incase anyone has one lurking...
  15. #31
    Join Date
    May 2005
    cumbria, the real north west
    Posts
    5,632
    Is that a great big art deco building?
    think I may have passed that a few times!
  16. #32
    Join Date
    May 2005
    Posts
    5,632
    I am thinking the same as you!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
