Garmin maps EUNT 2015.40 now available
A quick check and this now appears to only be a 1 time option at 1st install of the map onto device, you have to select as an option so miss it and its gone.. fekkas ......
Just checked and that's not the case that you can't get the option back if you didn't select it during the update. I updated my 660 and 590 this morning. Just plugged it back in, gone to Update tab and clicked "Reinstall maps" then on the next screen click "Advanced Options" and then select "Device & Computer"
The screenshot you show is not of the latest version of Garmin Express, it is the earlier version. IainMac's post was referring to what happens with the latest version of Express.
Indeed
So, I plug in my 660 and Garmin Express tells me that the update is there and will take approx 4 hrs to download. 2 minutes or so into the download it stops and says there was an error.
I tried again, a few times and get the same message.
I phoned Garmin Support who tell me to 'remove my device' from Garmin Express and then uninstall / reinstall Garmin Express which I did.
No joy, still the same issue.
Garmin Support have gone home now. Has anybody had the same issue? Any ideas as to what I could do to sort the problem??
Andres
........ one thing to consider is the size of the SD card, the latest update won't fit on a 4gb card, I had this problem and you don't get any message .....
Dave
CN2015.4 installed without problems on my Nuvi 2595 and Zumo 350. Did the Zumo on the desktop and the Nuvi on a laptop as I wanted the maps on both computers. All installed without problems. I'll look at the Reinstall option as I've another laptop that might benefit from having the mapping on it.
