Tyre soap is good but can lead to rim leaks on tubeless tyres.
I'd love to hear your theory behind that statement?
I have regularly found that a new set of tyres loose a few (only one or two) psi over the first 24 hours. I've always put that down to the bead / soap still being a bit fresh and needing to settle for a day or two ....
Tyre soap dries to a powder if used in large amounts it can cause a rim leak, hence tyre fitters use soapy water. When seating the tyre 60 psi then adjust to correct psi. Tyres should not lose pressure after fitting . as for people forcing it over the rim and fekking the rim they have no technique. You should be able to push the first bead on !
