My Famsa Tank Bag came without fitting instructions. Before I start faffing about, does anyone who owns this bag know which part of the headstock area the straps for the front of the harness attach to. Many thanks
It's possible that I've been sent the wrong harness fittings for my bag, I've been sent fittings with two plastic clips. Any info would still be gratefully received.
Just seen this, and you've probably sussed it by now, but if you want to check, here's how the base fixes -
One thing to note is that on the lower fixings the strap needs to be fastened through the two loops as you would a double D ring on a helmet, and not simply secured by the velcro. The velcro is there to stop the strap flapping and not to secure the base.
