- Joined
- Aug 3, 2009
- Messages
- 2,900
- Reaction score
- 102
Been trouble starting a few times but turned ignition on today and can't hear fuel pump priming, Any ideas?? Changed fuel pump controller, anyone had a fuel pump fail?
Looking here https://www.maxbmwmotorcycles.com/fiche/DiagramsMain.aspx?vid=51730&rnd=04282014 Looks like it is the same pump chap.
What are the symptoms? Ignition turns, engines turns over, but fails to fire?
So you have a "Markus" underseat tank plus a huge HPN tank and you still managed to run out of fuel and then blame the FPC.
OK.....
After a bit of playing around changing fuel pump controllers and taking the tank appart to swap the fuel pump over..
I realized that it should go into bmw for a recall..
I think they should fill the fuel tank to the brim so it lasts the entire life of the bike
I have a Hpn tank on it and although you can hear fuel sloshing around in it, the bike can not use the whole tank
Before you lot tell me so, i'm saying it myself..
I'M a cock
