Page 1 of 4 123 ... LastLast
Results 1 to 16 of 54
Thread: New LED lamps - recommendations please
  1. #1
    Join Date
    May 2002
    Dereham, Norfolk, today...
    Posts
    11,382
    As those who read my last ride report may be aware, I have had an unending series of failures with the current auxiliary lights I have fitted to my 1150 Adv...
    I have these fitted in two pairs, one of which comes on with the dipped bean and the other pair with main. They look great, have a good beam pattern, but are wholly unreliable - my last one lasted under a week before failing completely.
    I've been looking on eBay for possible replacements and have found the following ones - has anyone here had any experience of them and can let me know what they're like please?
    Link 1
    Link 2
    Link 3
    Link 4
    Link 5
    I think numbers 4 and 5 are probably unsuitable, as they seem to have a 'flood' beam pattern rather than a spot - I need to be able to adjust the pair that come on with the dipped beam so that they don't dazzle oncoming traffic. For resilience in use, I'd refer both pairs of lamps be the same.
    Anybody got good/bad experience of any of these - or indeed of other ones?
    Many thanks,
    Mike
    We will never be here again - have a good look around
  2. #2
    Join Date
    Dec 2005
    Hatfield,Herts
    Posts
    2,362
    I just ordered some of these as had forgotten just how pants the full beam is on my 1150. http://www.ebay.co.uk/itm/1910133452...%3AMEBIDX%3AIT
    Says they are fine to wire straight into the full beam, time will tell. Not sure if I will fit both yet, maybe leave it at one lamp.
    Please support London's Air Ambulance
    http://londonsairambulance.co.uk
  3. #3
    Join Date
    Jan 2014
    Gloucester United Kingdom
    Posts
    1,418
    I've fitted these to my 1200 LC.................. Been on for 3 months/2k miles.
    Still working, and oh so cheap compared to the ones that don't work !
    Good luck.
    http://www.ebay.co.uk/itm/1415862806...%3AMEBIDX%3AIT
  4. #4
    Join Date
    May 2002
    Posts
    11,382
    Quote Originally Posted by Gargy View Post
    Good luck.
    They're the same as my Link 2 then? Thanks...
  5. #5
    Join Date
    May 2002
    Posts
    11,382
    Quote Originally Posted by Stujw70 View Post
    Rectangular lights on an 1150 - are you mad?
  6. #6
    Join Date
    Jul 2009
    Gloucestershire
    Posts
    1,526
    I had number 2 on my 1150, no problems with reliability and very well made. I originally bought 4 and they were very flimsy, cheap tat....
  7. #7
    Join Date
    May 2002
    Posts
    11,382
    Quote Originally Posted by topcat2006 View Post
    They're leading the field
  8. #8
    Join Date
    May 2002
    Posts
    11,382
    Good luck.
    Right - ordered two pairs of them - let's see how they do...
  9. #9
    Join Date
    Dec 2005
    Hatfield,Herts
    Posts
    2,362
    Is it the norm for the various LED lights not to come with wiring looms?
  10. #10
    Join Date
    Feb 2012
    uk
    Posts
    115
    Denali, they are fantastic, dipping beam too ( which is illegal, but!!) they are expensive but compared to the rest, different league.
  11. #11
    Join Date
    May 2002
    Posts
    11,382
    Quote Originally Posted by otruk View Post
    Well they're certainly a different league in price...
  12. #12
    Join Date
    Sep 2012
    Torbay, England
    Posts
    25,952
    I have a pair of lamps that look like these on my 1200. The beam is narrow so only suitable to back up main beam. The beam is VERY long range.
    The case is billet alloy and hemispherical lens is glass. Mine came with 2mm aluminium "protective" shields which won't do much but look ok.
    I mine have a flashing mode so won't work with a dimmer so are suitable for main beam only.
    These say they have two power settings so worth a punt at £10 each.
    http://pages.ebay.com/link/?nav=item...obalID=EBAY-GB
    08 R1200GSA
    76 Suzuki GT750
  13. #13
    Join Date
    Apr 2011
    Jamaica Inn
    Posts
    1,126
    Mike.
    I have been using LINK 2 LED's on my 1200RT. Fitted over last winter, now done 9,000 miles. No problems.
    They recently sent me a link to buy a pair at £17.83 including free delivery.
    http://www.ebay.co.uk/itm/like/281808538907?lpid=82
  14. #14
    Maximum Mayhem Click here to find out how to Subscribe
    Join Date
    Jul 2008
    Breedon-on-the-Hill
    Posts
    1,123
    Quote Originally Posted by dr nosh View Post
    Mike.
    What sort of beam pattern do they throw? The description says "Spot Driving Lamp Foglight"
    Obviously it can only be one, not all. Or can you specify which you want?
    Sent from my D5503 using Tapatalk
    2k R1150GS '05 MX-5 1.8
    Ok, so I could only be young once; but I can be immature forever!
  15. #15
    Join Date
    May 2002
    Posts
    11,382
    Mike.
    That's what I've ordered
  16. #16
    Join Date
    Apr 2011
    Jamaica Inn
    Posts
    1,126
    Quote Originally Posted by buellzebub View Post
    Difficult to say really. They have not been used in the dark. Specifically fitted as permanent DRL's.
    You can't choose the beam pattern.
    From my limited tests I would say they are spots, but with flare on the outside. I have them mounted just above and forward of the exhaust header on my R1200RT. Quite low down really.
    They are 50mm dia, so will be limited in the beam that they can 'throw'.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
