Results 1 to 11 of 11
Thread: CCM 404E
  1. #1
    Join Date
    Sep 2003
    Northumberland
    Posts
    5,931
    CCM 404E
    Always wanted one of these since they first came out , visited the factory with a mate who was contemplating taking on a dealership but I was always put off by the £5500 price tag.
    Anyway this one came up on E Bay a couple of weeks ago , two owners from new , recent camchain a shed load of spares including three sets of plastics , swinging arm ,brakes, wheels , shock, forks, loads of engine bits, tank .
    Anyway took the plunge and bought it last weekend with a few changes in mind, took it out a couple of times but to be honest the low off road gearing and Michelin Enduro tyres made it a pain in the proverbial.
    Anyway this week I've been busy....reinstated the indicators and sorted out some bodged wiring , replaced the indicator switch , as the rear silver coloured wheel was more octagonal than round it was replaced with the spare black one with a new Michelin T63 tyre and a new 44 tooth sprocket replacing the 49 tooth item fitted , also changed the front and rear wheel bearings and at the same time put on the front black wheel with a matching T63 front tyre .
    Typically the tiny 6mm front and rear disc screws were all seized with stripped out hex heads and need be drilled out to change the discs .
    Once done I also swapped the swinging arm on which the bearings were hard up for the other replacement which was in good condition.
    Bike had been fitted with a cut down empty titanium silencer which was replaced with a repacked shorty Remus pipe with a home made db killer
    Finally the badly cracked rear plate was replaced with an off road only flexible plate bought off E Bay , so now finally I have my new winter toy to have a play on off road
    Attached Images Attached Images
  2. #2
    Join Date
    Nov 2005
    Newbury, Berkshire
    Posts
    12,195
    Very nice and not too expensive I'd wager?
    2016 BMW R1200 GS Triple Black
    2017 CCM GP450
    1980 Kawasaki Z1300
    2003 Sherco 250
    2002 Triumph Bonneville (Desert Sled)
    2017 Triumph Bonneville Bobber
    2003 Triumph Daytona 955i (Rob North Replica)
    1979 Yamaha XT500
  3. #3
    Join Date
    Sep 2003
    Northumberland
    Posts
    5,931
    Cost a bit more than the equivalent DRZ400E but less than a KTM or Husky (and hopefully less maintenance intensive than the latter) and considering the spares with it and its history I am happy enough.
    Cosmetically I didn't want anything too good as I then wouldn't want to take it off road .
    Tempted to fit the set of BAJA headlights I have in the garage loft
  4. #4
    Join Date
    Nov 2005
    Newbury, Berkshire
    Posts
    12,195
    The best bit about my old DRZ400E was the motor. Everything else lacked quality and had weight
    The CCM is a decent choice for a trail bike
    2017 CCM GP450
    1980 Kawasaki Z1300
    2003 Sherco 250
    1979 Yamaha XT500
  5. #5
    Join Date
    Sep 2003
    Northumberland
    Posts
    5,931
    Well sorted out a fully legal Simmi stainless oval can for the bike, will pick it up on Monday and I've been given a Boyesen Quickshot 2 to fit the Keihin FCR carb plus an extended fuel screw (both from a mate who used to have it fitted on an RMZ450 and they apparently make a difference to throttle pickup and they're free)
  6. #6
    Join Date
    Oct 2015
    Cork,Ireland
    Posts
    23
    Hey Neil,you should sign up to ccmmad if you are not already on it.There is also a ccm facebook page which is good too! congrats on the purchase from a fellow ccm owner!
  7. #7
    Join Date
    Dec 2009
    Canterbury, Kent
    Posts
    7,770
    Looks well that does....have fun
    Bounce
    KTM 1290 Super Adventure
    KTM 400 EXC
  8. #8
    Deadhead Member Click here to find out how to Subscribe
    Join Date
    Feb 2005
    Nottingham England
    Posts
    28,742
    It's the bike the DRZ should have been - nice one Neil, easily the best bike CCM have built in recent times and a perfect green lane bike
    Andres
    Quote Originally Posted by Charles Martel View Post
    One of the five imbeciles of the vainglorious big swinging dick types of the Harley section
  9. #9
    Join Date
    Sep 2003
    Northumberland
    Posts
    5,931
    Got the proper silencer today courtesy of Simmi performance, bike goes well with it fitted plus it is reasonably quiet, stainless steel and has a bs standard for £100.
  10. #10
    Join Date
    Sep 2003
    Northumberland
    Posts
    5,931
    Done a few hundred miles since I got the bike and it is a hoot if a bit thirsty, only thing I do not like is the amount of chain slap (due to no cush drive and the large suspension travel needed at the rear) so I started doing a bit of lateral thinking, the rear wheel and cush drive off my XLR250 fits so after a bit of digging I realised that the Suzuki DR350 has a similar sized wheel, a 220mm disc and according to Jt sprockets catalogue used the fitment sprocket as the CCM.
    Picked up a used wheel and cush drive and mocked it up with the spare swinging arm , a few mill taken off the cush drive to move the wheel to the left and the chain lines up and the Suzuki disc will be fine with the Brembo caliper and caliper carrier on the ccm.
    Hopefully a fully functional cush drive isn't very far away
  11. #11
    Join Date
    Sep 2003
    Northumberland
    Posts
    5,931
    Click here to find out how to remove these ads
    Did a 150 miles the other day of which 125 was on the roads and the rest off road , the fitting of the DR350 rear wheel and cush drive has made a huge difference to the ride with transmission and chain backlash almost cut down to nothing.
    Suzuki really should have fitted a 6 speed box to the DRZ though.
    I was out with a mate who was on his recently rebuilt CRM250 a bike which in the past used to run rings around my XR250 both off and on road , the CCM absolutely stuffs it both on the road and puts it to shame on the rougher stuff .
    All in all I am well chuffed with the way it is going , I had the forks rebuilt over the winter with new bushes and using SKF green seals and the same lad is going to do the spare WP rear shock
Posting Permissions
  • You may not post replies
  • You may not edit your posts
