Looks great, admire your skills
Any more 'in between' pics to whet our appetites
To be honest there isn't much to show.
The original idea was to build a cut down roadster on a shoestring budget. I tried a few ideas out but I really couldn't get on with the high footpegs. the relationship between the footpeg and the seat means you have to squash your legs up putting a real strain on your hips. theres no way to drop the pegs lower because they foul on the exhaust system.
The frame was too far gone for the originally planned spray over and touch up so it was off to the powder coaters for blasting and coating
The rest of it was just a reverse of the original strip down
I was lucky that a previous owner had removed every last nut and bolt and greased them before refitting them, even the dreaded front engine bolt had been removed and greased so hadn't seized up.
Im expecting to spend another £1000 on it to finish it off by which point it will be pushing £3,500. I've sold a lot of the original parts and and still have a spare engine, carbs, wheels and a few other parts that were part of the original deal. By the time I've done I should get back the best part of a £1000 for all the parts so the bike should stand me around £2.5k
Guzzi parts are still very cheap. The black tank in the photographs is an unused old stock tank from Holland. £165 delivered, however it has a dent in the other side so needs filling and spraying. The biggest expense was the wheels and the seat. The seats a high quality reproduction and has a leather cover. I'll be happier when the white settles down a bit as its very bright at the minute.
The cali frame rails, side stand and running boards were very reasonable, a few years ago running boards were and frame rails were big money but theyre out of fashion at the minute. my orignal frame rails fethched good money so went a good way to offsetting the cost of the cali bits.
The box of spares that came with the bike had a load of new bearings and other useful parts that have saved me a lot of money, unfortunately some of the parts with a potential high resale value have proved to be knackered (camshaft and a few other bits) but I do have a few choice parts in there like Le mans breathers, distributors and a complete alternator/ diode board/ rotor setup and starter motor which will all fetch good money.
Biggest mistake was buying the shock factory shocks. They were three hundred quid for the pair and initially looked to be really well made, however, the bodies are wider than most shocks which fouls the rear brake mounting plate and if you mount them upside down (as the stickers would imply they should be mounted) the shock also fouls the bevel box. The springs are incredibly hard and supposedly sized for me but even with my 18.5 stone jumping on them they barely move which is going to cause issues on the road. I've spoken to them about it and was basically fobbed off with a suggestion that I need to ride the bike to give the springs chance to bed in and soften up (if it smells like bullshit...)
I'll post more as it progresses
