and relax...
I have just ridden one for 40 miles. It's a nice bike but not a great one. Tracer is unlikely to become unloved.
2 things on the Africa Twin that are better out of the box are the seat and front suspension. Seat has plenty of room and like most big trailies you can slide forward to a narrower but at the front but unlike some bikes, you can slide back onto a wider part but not feel like you are detached from the bike.
Screen: not adjustable, aftermarket suppliers will be busy. It was especially bad riding into a headwind.
Engine: it spins up nicely and provides plenty of power. Noise is a bit wanky. Apparently there are valves to make it sound like a V twin. I felt I was riding a sousaphone.
Front suspension: I wish my Tracer handled bumpy roads as well. Gets a bit floaty over 90mph.
Rear suspension: summed to chatter a bit, may need adjustment. It was on a fairly soft setting, presumably so the bike squats for shortarses hopping on in the showroom. I didn't mess with the knobs.
Top speed: didn't find it. Got to an indicated ton at times and it was not a pleasant place to be, even tucked behind the tiny screen.
Finish: looks okay. Switchgear is okay but easy to hit the horn rather than cancel the indicator.
Dash: I didn't like the layout. It wasn't easy to see when heading into bright sunshine - on the Tracer, you look down but the more vertical display on the AT means you are looking into the sun and your eyes can't adjust for the contrast.
Handling: okay. Holds a line on fast sweepers with the OE Bridgestones. Needed less countersteering than I was expecting. Turns in okay. Pretty neutral.
Brakes: pretty good. Little fork dive. Engine braking is like hitting a brick wall which is how I like it with a big bike like that.
