Results 1 to 11 of 11
Thread: Sickly Bandit
  1. #1
    Join Date
    Feb 2009
    Flitwick, Beds
    Posts
    1,613
    Sickly Bandit
    Any Suzuki bods out there that can offer some technical, and hopefully model specific experience based advice please?
    Ok, so over 3 years ago I bought an 01 face lift 1200 Bandit from another member on this forum. It was sold as a non runner/project, although it did run, but only from cold on choke, and was unrideable as it was.
    With initial enthusiasm I started by stripping the carbs, cleaning the jets etc, fitting new plugs and air filter, but no joy. I'll say at this point that there were no signs of anything in the way of muck or rust in the carbs or the fuel in the tank.
    Some months later, due to other jobs needing my attention, I tried a second hand set of coils and plug leads, trying both replacement sets and one original and one replacement in various orders, but again, naf all difference.
    More time past and one day I read a post on a bandit forum that said about replacing the diaphram in the vacuum part of the pet cock, so I did and hey presto she ran. Not perfect, but a huge difference, enough to think I'd sussed it. I tried balancing the carbs, but found one really lazy, so I bought a new carb diaphram and rebalanced, she then ran as sweet as.
    I was so pleased I booked an mot and off I went.
    All was fine until I got about 3 miles down the road, onto the first stretch of open road, opened her up, got to 3-4000 rpm and nothing.....no more urg until it got to about 6-7000 revs, then it took off again. It did this all the way there and back.
    She got dumped at the back of the garage again. I kind of decided I needed to either replace the carb mounting rubbers, or add a little rtv to help them seal, thinking air was getting in weakening the mixture. Losing interest I left it for another day.
    So here we are over a year later, with some new enthusiasm. I decided I'd start by doing the head bearings that the mot had advised. I also freed off the calipers as they had started binding when pushing her about in the garage. With that done I pinched the battery off my Bird, as the original had long since died, but nothing.... As dead as Turned over fine, but no attempt to fire, but also no smell of fuel.
    I stuck a fresh gallon in, but still nothing. That was Saturday morning. Sunday I tried again, switching the pet cock to prime. After some cranking she started to cough a little, but I gave up as she started smelling a bit weird. Like the starter was burning out, but it was cold to touch.
    Anyway tonight I've tried again, and she's back to where I was when I bought her. She'll start on choke, just. But you can't rev her until she's warmed up, but you couldn't ride her even then. And the exhaust gets really hot, so I've got excess fuel burning in there I reckon. Doesn't seem to matter where I have the pet cock either.
    I've been wondering about doing the valve clearances, but that wouldn't cause her to not run, then run, and not run again, although it might explain the poor running when I thought I'd got her sorted.
    I was hoping there was a something that's a common cause, but from reading on the Bandit forums they all seem to suffer all sorts of faults with all sorts of fix's and solutions.
    Any ideas? Other than wheeling her out onto the front garden, draining the fuel over her and striking a match, cos I've already considered that one
  2. #2
    Join Date
    May 2010
    Falkirk, Scotland
    Posts
    1,899
    Have you thought of - http://suzukiownersclub.co.uk/
    Might have some ideas, assuming you've not already joined....
  3. #3
    Join Date
    Jul 2010
    Overland and classic,vale of belvoir,Melton Mowbray
    Posts
    3,966
    Take a good look at the throttle needles and emulsification tubes,they can wear and it makes it run really rich through the midrange.
    Try dropping the needles one or two grooves to see if it improves it.
    overland and classic
  4. #4
    Join Date
    May 2008
    angus scotland
    Posts
    2,042
    Sorry can't help,but this lad might give you some ideas.
  5. #5
    Join Date
    Feb 2009
    Flitwick, Beds
    Posts
    1,613
    I've already done the fuel tap. But I'm wondering if being left idle for a year or more has seized it back up again. I know the bike hadn't been used for a good couple of years prior to me getting it as the previous owner had bought another bike, and it was what got it going for me previously. Think I'll pull it off and recheck it.
    If I can get it running again I can then play with the needles as Mikey suggests.
  6. #6
    Join Date
    Feb 2009
    Flitwick, Beds
    Posts
    1,613
    Pulled the fuel tap out tonight, took it apart but couldn't see anything wrong with it, but once back together she starts.
    Not perfect, but way better that the other day. Looks like after less than two years I may need another service kit for it.
    Or can I ditch the vacuum side of things?
  7. #7
    Shep of the Dessert Click here to find out how to Subscribe
    Join Date
    Nov 2004
    Lleyn Penninsular
    Posts
    12,554
    I'd be looking at running it without the tap for now just to prove a point, then if its still messing about i'd be tempted to get the carbs cleaned properly (ultrasonically) again just to prove a point.
    A man with no boat is a prisoner.
    Faroese proverb
  8. #8
    Join Date
    Jan 2009
    Co. Meath Irish Rep.
    Posts
    5,071
    Your hunting down somthing that somthing else may be masking. I'd try running with a temporary gravity fuel supply to eliminate any question on the fuel supply end of things. If she's sucking air from somewhere she shouldn't a can of easy start can help if she picks up when you spray at a suspect rubber that will tell. How are the plugs I've read your long post and can't remember if you mentioned them. Are they good and correct fitment? You might check valves just to eliminate them. I've heard stories of ignition problems on grey import bandit 400. A friend had one that was running erratic and he gave up in the end. JJH
  9. #9
    Join Date
    Feb 2009
    Flitwick, Beds
    Posts
    1,613
    Quote Originally Posted by Shep View Post
    Just trying to suss a way of bypassing the diaphram, wondering if I can fit the spring on the inside so it holds it open rather than closed?? Might try that tonight.
    As for cleaning the carbs, they're already clean. First thing I tried, and they're wasn't anything in them to talk of, so I'm reluctant to pull them apart again.
    I want to get it mot'd and taxed so I'm legal to test ride it. Then I can try out some of the other ideas.
  10. #10
    Join Date
    Nov 2004
    Lleyn Penninsular
    Posts
    12,554
    Quote Originally Posted by Littledumptruck View Post
    Perhaps you did a 100% job on the carbs, only you know if you did or not, but I know i've cleaned carbs that have been cleaned 'properly' by others, and they've turned the detergent in the ultrasonic cleaner brown.
    It is probably the tap, it sounds as if you could tell if it were still playing up quite easily so i'd just hang a petrol filled plastic bottle from the garage roof rafters and jury rig a pipe to the carbs. No need to ride the bike to find out. If it is still messing about then you need to decide if you've done a good job on cleaning the carbs.
    Faroese proverb
  11. #11
    Join Date
    Feb 2011
    North Ayrshire
    Posts
    262
    Yes I agree with Shep, try an independent fuel source and that will tell you if the bike runs cleanly and smoothly without the fuel tap/ diaphragms etc.
    I had the same problems with an old Gsx600f and it was the fuel tap which was goosed, eventually bought a new one. ( tried stripping it, but it was unserviceable).
    Try going to your local refuse /amenity/tip and get hold of the fuel tank from an old petrol lawnmower or petrol strimmer, this is an ideal aid to solving your problem.
    These lawnmower fuel tanks occasionally come with a fuel shut off tap and hose, so much safer than a plastic bottle.
    Tie it to the garage rafter above the bike and test.
    Also check the vacuum hose from the fuel tap to the carburetor for blockage and splits. Once the engines running with the independent fuel tank, there should be air being drawn( sucked) throught the vacuum hose to the carb.
    Hope this helps.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
