Page 3 of 3 FirstFirst 123
Results 33 to 40 of 40
Thread: BSA A65
  1. #33
    Never knowingly understood Click here to find out how to Subscribe
    Join Date
    Nov 2005
    South Yorkshire
    Posts
    17,018
    From my 1966 original BSA brochure. The 650 Spitfire Mk II Special (A65SS) looked a mean bugger. Those Amal GP carbs made it a beast, tamed down in the later models by Concentrics
    Adventure.GS
    Tours, training or custom made earplugs ... it's all here.
    "If you want the rainbow then you have to put up with a little rain" Dolly Parton
  2. #34
    Join Date
    Mar 2014
    Cambridge
    Posts
    125
    Update: Gorgeous 4 gallon fuel tank sprung a leak! Ive been using it regularly and I think the vibration has rubbed a bit of the solder away. The wet patch under it is actually petrol....
    Attached Images Attached Images
  3. #35
    Join Date
    Nov 2015
    Lincolnshire, England
    Posts
    1,461
    Is it one of those Indian tanks? Had one on my A65 and the fucking thing leaked from new. Ended up getting hold of a original export tank.
  4. #36
    Join Date
    Mar 2014
    Cambridge
    Posts
    125
    Yes it is, doesn't fit particularly well, had to make up all sorts of bracketry to hold it in the right place. I just bought a tin of tank sealant to see what it does, failing that theres a local guy that's very good with a soldering iron....
  5. #37
    Join Date
    Nov 2015
    Posts
    1,461
    I'd highly recommend POR15 as a tank sealant, get the kit as it comes with a cleaning solution and etching primer. Follow the instructions properly and it's good stuff....I've sealed some right colanders with it.
  6. #38
    Join Date
    Apr 2010
    Lancashire , England
    Posts
    1,526
    Quote Originally Posted by trickytree View Post
    Plus 1 for above BUT follow the instructions to the letter. These polyurethane epoxy blends use moisture in the atmosphere as part of the curing agent. So if the tank is moist following the metal ready process, the POR will surface cure and not through cure, so it will peel off. Lots of videos on the net showing how to do.
    I used the wifes hair dryer to really dry out the tank , point it in the fuel filler and exhaust through tapping for the pet cock. Sorry pictures upside down Que Australian jokes.
    Steve
  7. #39
    Join Date
    Mar 2014
    Cambridge
    Posts
    125
    Ive been offered my dream bike, a Panther M100, so the A65 is now officially up for sale....!
    MOT Jan 2018, matching numbers, 20 years worth of MOTs. Starts and runs perfectly.
    £4750 ono.
  8. #40
    Join Date
    Dec 2005
    Embra, Scotland
    Posts
    6,889
    Click here to find out how to remove these ads
    Get thee behind me Satan! No room in the lock up ... No room in the lock up ... No room in the lock up ... No room in the lock up ... No room in the lock up ... No room in the lock up ... No room in the lock up ...
Posting Permissions
  • You may not post replies
  • You may not edit your posts
