Results 1 to 7 of 7
Thread: changing shocks
  1. #1
    Join Date
    Sep 2009
    Callington, Cornwallshire
    Posts
    1,305
    changing shocks
    Any of you technical guys know how hard it would be to change a set of lowered shocks from a 2013 gs lc to a 2015 gsa lc and vice versa. is it a plug n play what with the esa etc Or is it more complicated
    Any info would be welcome
  2. #2
    Join Date
    Feb 2010
    Here and there.....
    Posts
    3,717
    I think GSA and GS shocks are different lengths.I would imagine lowered GS shocks on a GSA might look a bit shit!
  3. #3
    Join Date
    Sep 2003
    Northumberland
    Posts
    5,409
    Stands will need to be changed and as a replacement ESA shock has to be coded/calibrated to the ECU by the dealer I would assume that it will not be a case of plug and play
  4. #4
    Join Date
    Sep 2009
    Posts
    1,305
    Quote Originally Posted by Johno23 View Post
    I thought the gsa and gs are the same frames so to lower either its just putting the lower or normal shocks depending on buyers choice at the factory .
    So a wee bit more complicated than plug n play . thanks anyway
  5. #5
    Join Date
    May 2009
    ilkeston
    Posts
    195
    I changed my rear shock in Kazakhstan at the side of the road, new unit worked perfect when plugged in, not been coded or calibrated at all.
  6. #6
    Join Date
    Aug 2010
    Paradise
    Posts
    21,082
    Just let a bit of air out the tyres, Steve!
  7. #7
    Join Date
    Sep 2009
    Posts
    1,305
    Quote Originally Posted by The Nutty GSER View Post
    Twat......
Posting Permissions
  • You may not post replies
  • You may not edit your posts
