Page 2 of 2 FirstFirst 12
Results 17 to 30 of 30
Thread: Following Tim's example........
  1. #17
    opinionated, me? Click here to find out how to Subscribe
    Join Date
    May 2005
    Kelsall, Cheshire
    Posts
    4,810
    Quick update, for anyone who may be interested!
    The rear brake pedal had been hand made by the previous owner, and while a piece of art to look at, was next to useless as a control. Far too short and flexible, even for my dainty little feet! Being on the "wrong" side as well meant it wasn't intuitive, so when I did find it, it needed to have a decent area for me to stand on. Looking at various options, someone suggested that a Sammy Miller Products pedal should be ideal, and for £35.00 not too expensive. The footrests were horrible narrow things, exactly the same as standard on a 1200 GS Hexhead! Ebay turned up a set of alloy pegs, both wider and lower than the originals, which was perfect, and again only £35.00!
    This is the best position for working on the clutch....
    The friction material on the old clutch plates was in poor order, and the pressure plate was a thin bendy affair, with only three springs holding everthing together. My problem was mainly when kickstarting the bike, as with old fashioned engines, you turn the engine over via the clutch. If it slips, you struggle to start it. Apparently this is a common "Cub" issue, and plenty of aftermarket goodies are available to help. Mainly by lightening your wallet.
    The old .
    And the new.
    Four (thinner) friction plates instead of three, relined clutch basket, new springs and an alloy pressure plate. The centre bearing is now 16 rollers, instead of 16 balls, which is apparently much better. The biggest single improvement though, is through changing my kickstart technique. I am used to kicking big two stroke singles over, so was giving the poor little Cub too much wellie! A steady push through works better.
    I've also stripped down the forks, cleaned out the sludge that was in there, and replaced it with 15w fork oil. Now the forks work a whole lot better, but finding cut down MX springs in there was a bit of a shock! I'm sure I can make these better still with a bit of experimentation.
    In between this twiddling, I have now completed 3 trials on it, and am really enjoying it. The last trial was on Sunday, at one of our favourite venues. Tim was free, so he got to see the bike in the metal for the first time. The club had set some new sections on the other side of the farmer's land, so we had three field margins, a green lane, and a tarmac driveway to blast along in top gear! Immense fun! Tim's BSA has the edge on top speed, but it doesn't wheelie quite as well, does it Tim?
    One of the problems of using these old classic bikes "in anger" as it were, is that they don't crash quite as well as the modern bikes. And inevitably, at some point, you and the bike will part company. If not, you are either very skilled, or in the wrong class!
    Section 9 of Sunday's trial was my nemesis. A climb up a rocky stream bed, then turn out to the right, before turning back to cross through the stream and up the left hand bank. The bank didn't look too bad, but when I hit it on the first lap the back wheel spun out from underneath me, and I ended up underneath the bike, facing the opposite direction, with my fingers trapped between the clutch lever and the ground. That'll be a five then.
    On the second lap, I went at it a little too cautiously, and the bike only slipped down the bank, still facing the same direction. When I picked it up though, I'd put a fist sized dent in the tank.
    In all the crashes, get off's and drops I've ever had (and believe me, that's a lot!), none has made me feel sick. Until this one.
    I didn't manage that section on the next two laps either, finishing with a total of four fails. Small comfort came from the results, where seven other riders in my class had the same.
    The section had been cleaned though, so it wasn't impossible. Just not by me.
    Today I took the tank into work, and we tried blowing the dent out to no avail. There is an excellent bodyshop near the office, so I took it round to them to see what they could do.
    And this is the result. Not perfect, but at least I feel better now!
    Mark
    Just when you've got this rat race licked, here come faster rats!
  2. #18
    Moderator
    Join Date
    Aug 2008
    Cheshire
    Posts
    10,234
    Ouch - bad news about the tank but in the end you got it for using and the next dent won't make you feel as sick
    Clutch looks good
  3. #19
    Good job Mark, tank's better than new
    A far as wheelies go's, I'm not sure it was all down to the short comings of my bike
    KEA
  4. #20
    Join Date
    May 2005
    Kelsall, Cheshire
    Posts
    4,810
    Further update:
    A few months ago, at one of my favourite trials grounds, Kynaston's farm at Trevor, near Llangollen. A mate of mine is in training for the Scottish Six Day trial in May, and whereas I can't help him too much in the skill stakes, I can pick him up if he gets it wrong! We had a swap for a few minutes, and his bike is absolutely sublime, if a tad too modern for my tastes.
    One of the issues I have been having with the Tiger Cub was the flimsy fork yokes. On more than one occasion I had the disconcerting experience of the bars seeming to turn independently of the wheel, especially in rocky sections. Telford Classic Dirt Bike show in February gave me an opportunity to compare what yokes were available to stiffen the front end, and provide some interchangeability (is that a word?) for me to try other forks if I wanted. Alan Whitton engineering ticked all the boxes, and a couple of weeks later a box arrived with some shiny alloy bits in it. These duly fitted to the bike have improved things no end, there is still some flex compared to the modern bikes, but I now have more confidence that the wheel will go where I want!
    Another shot at Kynastons, and no, the chain tensioner shouldn't be hanging down like that. It has just lost an argument with a rock.
    Next on the "to do" list, apart from a new tensioner, is new chain and sprockets. Not quite as straightforward as I'm used to, you have to take the clutch and primary chain off to get at the gearbox sprocket!
    Mark
  5. #21
    Join Date
    Jan 2002
    North Yorkshire
    Posts
    32,197
    Love the Repsol...............but I'm biased
    Your bike looks the busines too
    JohnnyBoxer
    So many roads...........So little time......
  6. #22
    Great update Mark.
    KEA
  7. #23
    Join Date
    Jan 2013
    Bonnie Dundee
    Posts
    356
    Tidy bike , The Repsol will feel a lightweight in comparison.
    How did your pal get on with the SSDT ?
    I was an observer this year ,and ordered all the good weather
  8. #24
    Join Date
    Apr 2016
    Hamps Wilts Berks Triangle
    Posts
    145
    Great thread, and smashing bike.
    Anyone know what's down in Hampshire to go and watch and pick up the bug.
    R1200GSA TB
  9. #25
    Join Date
    Jan 2002
    North Yorkshire
    Posts
    32,197
    Quote Originally Posted by w-w View Post
    R1200GSA TB
    Google Trials and Moto X News
    They have a weekly 'What's on Section' for every off road bike sport discipline
    JohnnyBoxer
  10. #26
    Join Date
    May 2005
    Kelsall, Cheshire
    Posts
    4,810
    Quote Originally Posted by ossa eck View Post
    Lonny got a 2nd class award, only 8 places down from a 1st. He really enjoyed it, especially the weather! I suspect he will be back for another go.
    Mark
  11. #27
    Join Date
    Apr 2016
    Posts
    145
    Quote Originally Posted by JohnnyBoxer View Post
    Thanks for the link, I hadn't found that site when looking.
    Looks like there is an event only 30 miles away in North Berks. Coolio
    R1200GSA TB
  12. #28
    Join Date
    Apr 2016
    Posts
    145
    Quote Originally Posted by earthmover View Post
    Don't want to hijack the thread again....
    But seeing your bike has sparked an interest. So much so I can now spot that Repsol as a 4rt
    What a friendly bunch of people at trials events. I went to one at the weekend to get an idea of what goes on.
    Looks like I'm on the hunt for a bike, I think I'll give a modern one a go before I look at a classic.
    R1200GSA TB
  13. #29
    Join Date
    May 2005
    Kelsall, Cheshire
    Posts
    4,810
    R1200GSA TB
    Be careful, it's addictive, and harder than it looks!
    Mark
  14. #30
    Join Date
    Mar 2015
    Scotland
    Posts
    1,001
    Click here to find out how to remove these ads
    I tip my hat to anyone who rides these old girds. Nae brakes, nae power and nae suspension and even more respect to get rid of a modern bike for one.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
