Hello folks,
I bought an 09 adventure with a few faults that I thought( stupidly) would be an easy repair. One of the faults was an abs warning on the dash. Although the brakes worked fine, the abs side was not tested on the road, I decided to look into fettling it. I purchased the gs911 tool and set about clearing all the faults it showed, unfortunately the abs pump motor was deemed faulty, showing the code 24048, pump motor power supply defective.
After trawling the web to find out about the fault I stripped the abs module and found the motor to be fine by connecting it to a direct supply, along with checking the bearings and brushes whilst I had it apart from the unit. After that failed to fix it, I sent it off to ECU testing and had it rebuilt, even though they deemed it to be working. It still has the same fault! (24048). I have tried to perform the various ABS output tests, but the gs911 is "unable to communicate with control unit" now. I have also gone through the wiring and connections using the Haynes diagrams, nothing obvious there either. The front brake lever operates without any fouling on guard and neither brake switches are active( brake light off until brakes applied).
Has anyone else had this problem, if so did they manage to fix it?
My next course of action will be to bypass the ABS altogether and disable the annoying warning lamp in the clocks, not the ideal situation, but I want to ride the bike at some point.
