It seems from reading the forum, that the most common reason for having to change the clutch on the 1150GS is not due to it wearing out, but due to leakage from the slave cylinder contaminating the clutch. Therefore since my bike is a 1999 model with 105000 miles and still on the original clutch and slave cylinder, would it be a good idea to make a pre-emptive change to a new slave cylinder before it does fail?
I always pop the bike into neutral when stopped for a few seconds to reduce the time the slave cylinder is operating, and regularly check the clutch fluid level and that it is clean, but am concerned that the slave will fail suddenly or when I am on a long trip. At around £100 for a new one they aren't cheap, but a lot cheaper than having to replace a clutch that may not be worn out.
