Results 1 to 5 of 5
Thread: 4RT valve clearance check
  1. #1
    Join Date
    Sep 2015
    Cumbria
    Posts
    101
    Decided to check the valves on my 4RT today and haven't done it on this before but have on previous bikes.
    All 4 valves were tight, couldn't get the feeler gauges under any of them so set it to TDC (checked Pistons was at top too) set the crank on the mark and slackened the adjusters, wound the tappet out reset to correct clearance then put all back together.
    When I tried to start it it now has massive compression, it will turn over and can't hear anything untoward but doesn't want to start and the compression just feels wrong, so gave up for the day and to think.
    I must be missing something very obvious but any one any suggestions?
  2. #2
    Join Date
    Jan 2002
    North Yorkshire
    Posts
    32,495
    Are you sure you had it on the right stroke?
    Have you got the manual?
    JohnnyBoxer
    So many roads...........So little time......
  3. #3
    Join Date
    Sep 2015
    Cumbria
    Posts
    101
    Yes to both, valves were rocking before tdc, and piston was at the top??
  4. #4
    Join Date
    Jan 2002
    North Yorkshire
    Posts
    32,495
    Ask on TC then?
    JohnnyBoxer
  5. #5
    Join Date
    Jan 2013
    Bonnie Dundee
    Posts
    384
    Quote Originally Posted by Hoggyf View Post
    Turn it through one revolution of the crank,so cam lobes are facing away from adjusters.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
