What happens if you just unplug the thing?
Must still be fitting the bad batch to 16 plates too.
What's an exhaust valve?
It's that thingy, that squeaks when you turn the bike off, oh and then it stops squeaking, because it's seized.
Terry
No it's not. It's the valve/s in the cylinder head that are opened by the camshaft and closed by spring/s. JJHIt's that thingy, that squeaks when you turn the bike off, oh and then it stops squeaking, because it's seized.
Terry
What does one do with the exhaust valve when one fits Agro headers??
If so said:What happens with the cables? Do you get warnings showing and/or do you need to have the bike's canbus system tweaked to tell it the valve is no longer there?
If you disconnect the cables from the actuating motor the valve still thinks its working as its gone thro it set up movement , so this wont thro up a code. Worked for me.
So on the shelf you should have original pipes and the cables and the cover plate (plus a few bolts)
Thanks, that's nice and simple for once.
