Results 1 to 13 of 13
Thread: Autocom Installation on new GS LC
  1. #1
    Join Date
    Mar 2013
    Norwich, Norfolk
    Posts
    43
    Looking to install my autocom spa on my new gs. Haven't got a degree in electronics, so does anyone have any advice and ideally pics please? Thanks in advance!
  2. #2
    New Member (less than 15 Posts)
    Join Date
    Aug 2016
    Chelmsford
    Posts
    7
    Just move the tyre senser moniter over a bit to the right Sam at chainspeed did mine yesterday the unit then goes right back in the tail it goes in long way then you twist it 180 so cables are facing out
  3. #3
    Join Date
    Jan 2013
    South Yorkshire
    Posts
    915
    What year LC fella? If its a 16 build on, it will have the flashy brake light module and lean sensitive abs module under the back seat as well, bugger won't fit then.
    Sent using Tapatalk
  4. #4
    Join Date
    Mar 2013
    Norwich, Norfolk
    Posts
    43
    Yep it's a new one so has all modules under back seat. Might try taking rear rack off and seeing if it will fit right in back as suggested by Spartacus. Don't want to sell it as I get on with it so well.
  5. #5
    Join Date
    Jan 2013
    South Yorkshire
    Posts
    915
    I ended up with this before i switched to bluetooth
    https://r.tapatalk.com/shareLink?url...re_pid=4261160
    Sent using Tapatalk
  6. #6
    Join Date
    Mar 2013
    Norwich, Norfolk
    Posts
    43
    Thanks Roadcraft, where did you pick up the switched live from?
  7. #7
    Join Date
    Jan 2013
    South Yorkshire
    Posts
    915
    Used the Autocom power lead with filter straight off the battery. Cable and socket long enough to route up to the back seat.
    Sent using Tapatalk
  8. #8
    Join Date
    Apr 2010
    Aradippou, Cyprus
    Posts
    445
    Check under the front seat for fitting the spa. There is more room than you think, especially if seat is on high.
    Ian.
    If you can't be good, be careful
  9. #9
    Join Date
    Jun 2013
    Belfast
    Posts
    22
    Placing autocomplete under the seat
    Quote Originally Posted by hatzyian View Post
    Placing it under the seat gets a lot of interference from the ignition unit, just for reference anyone looking at this now
  10. #10
    Join Date
    Mar 2005
    Bracknell
    Posts
    2,636
    I've been told it should fit under back of rear seat unit even if you have to take it all apart? I will find out in a month when I get my new bike as I have a Spa unit?
  11. #11
    Join Date
    Mar 2005
    Bracknell
    Posts
    2,636
    Fitted my SPA unit today in the rear section
  12. #12
    Member
    Join Date
    Aug 2015
    Hull, East Yorkshire
    Posts
    95
    That's fine if you haven't the alarm fitted. Otherwise its a no go.
    Have managed to squeeze mine in by moving the TPS unit forward and left ( as per the above photo ) and leaving loose. The Autocom I have wrapped in bubble wrap and slid as far back as possible. The Bluetooth module sits slightly forward and right of the Autocom.
    Mindfull of the units being trapped between the bottom of the seat, particularly if there is a pillion passenger, and the mudguard.
  13. #13
    Join Date
    Jul 2010
    Hull
    Posts
    2,571
    Im thinking of going back to a wired unit but think it will have to be another Starcom unit as its smaller and has a remote volume control.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
