Results 1 to 13 of 13
Thread: Switch warranty
  1. #1
    Member
    Join Date
    Dec 2012
    United Kingdom
    Posts
    27
    Switch warranty
    Hi, looking for some information on replacement parts please.
    10 months ago I had the right hand switch set changed whilst the bike was within its initial 2 year warranty period.
    This set has failed again.
    I do have the extended warranty but kinda think it should be changed under the consumer act / sales of goods act?!?
    Obviously I didn't pay for the last set, covered under warranty, but you'd expect them to last longer than 10 months. Well from another manufacturer you would... The bikes covered less than 4k since this switch set was replaced.
    This is the 4th set that's needed replacement! 3 right, 1 left. It's a k1600, 2014.
  2. #2
    Join Date
    May 2010
    Wandsworth, London
    Posts
    2,964
    I think BMW will honour the 2 year warranty on that part. I looked this up recently and found a bmw website stating the 2 year on genuine parts. Depending on your dealer but I would also expect it to be covered. Why not call a dealer and make an enquiry without prejudicing your chances first off, before approaching your own dealer if they are sticky...
  3. #3
    Join Date
    Jul 2014
    Gloucestershire UK
    Posts
    2,434
    BMW changed the indicator switch on my K1300s outside of the guarantee period. Their switches are shit and they've been using them since 2009. I've had several changed on numerous bikes and it amazes me that they don't recognise the problem and update them.
  4. #4
    Member
    Join Date
    Dec 2012
    United Kingdom
    Posts
    27
    Thanks for the replies. Kinda reinforced what I thought. Going to give them a call tomorrow when the service manager is in. Thanks again
  5. #5
    Join Date
    Jul 2010
    Hull
    Posts
    2,662
    I had both switch set changed FOC late last year on a July 2012 RT. Its a known problem.
  6. #6
    Ooh me Chalfonts Click here to find out how to Subscribe
    Join Date
    May 2002
    Buckinghamshire
    Posts
    3,911
    I believe that the switch should have a warranty of its own. That was the impression I got when one of mine was replaced, so it might be worth asking your dealer.
    Keefffff
    I can only please one person a day. Today is not your day, and tomorrow does not look good either..
  7. #7
    Join Date
    Nov 2005
    Newbury, Berkshire
    Posts
    12,100
    Officially, the switch you had fitted under the manufacturers warranty will only come with the remaining warranty for the vehicle to which it is fitted. So if they fitted a switch at month 18 it would only have a 6 month warranty. This is because you didn't pay for it therefore the warranty remains with BMW. Had you paid for it the part it would have had a 2 year warranty
    As you now have an extended warranty (officially) the warranty company should pay for it, but if I were you and my extended warranty had an excess? I would expect BMW to either pay that excess or fit a new switch FOC
    Either way you shouldn't be out of pocket
    2016 BMW R1200 GS Triple Black
    2017 CCM GP450
    1980 Kawasaki Z1300
    2003 Sherco 250
    2002 Triumph Bonneville (Desert Sled)
    2017 Triumph Bonneville Bobber
    2003 Triumph Daytona 955i (Rob North Replica)
    1979 Yamaha XT500
  8. #8
    Join Date
    Nov 2005
    Newbury, Berkshire
    Posts
    12,100
    PS my understanding is that (unofficially) these switches now have a 5 year warranty because they are so shit
    2017 CCM GP450
    1980 Kawasaki Z1300
    2003 Sherco 250
    1979 Yamaha XT500
  9. #9
    Member
    Join Date
    Dec 2012
    United Kingdom
    Posts
    27
    Shows what I know.... New starter motor fitted.
  10. #10
    Join Date
    Feb 2011
    Standish (M6 J27)
    Posts
    369
    When you have new parts fitted toward the end of the warranty period, insist on paying a nominal amount the item, maybe 5% or the cost or minimum £5.
    This enables you to claim at any time during the warrantied life of the part.
    C1 200 (2001)
    R100 RS (1990)
    R1200RT (2005)
    K1200R Sport (2007)
    NSU Quickly N (1964)
    Honda 400/4 F1 (1977)
    Moto Guzzi V1000 Convert (1978)
    Triumph Street Triple R (2013) - Wifeys
    Standish (M6 Jn 27)
  11. #11
    New Member (less than 15 Posts)
    Join Date
    Jul 2017
    Tadley, England
    Posts
    2
    I have just bought a new LHS switch on EBay from the US.
    The hazards and left indicator stopped working and I have investigated that this is a common fault with the combination switch - especially in hot weather.
    However, the bike is touching 30,000 miles and I suppose the switch was due to play up?
    The next issue will be how to remove the faulty switch from the handlebar? I have already found out that it is not as straightforward as it should be.
    I have not involved the dealer (bought the bike 18 months ago)- maybe I should do?
    Anyone know how to remove the switch gear?
  12. #12
    Join Date
    Jul 2017
    Tadley, England
    Posts
    2
    Just replaced the LHS switchgear on my K1300s with the EBay sourced 2nd hand one from the USA. IT WORKS! Now my RH indcator works and the Hazzards as well as all the other functions.
    I found a hidden screw under the heated grip. Once the grip was slightly peeled back the screw was visible. I removed the screw and the bar-end weight and the assembly slid off with just some minor fiddling about with the switch connectors (3 in all). I did look carefully at the replacement unit to get an idea of where everything went. Much easier than trying to work out how to disassemble it by using logic. Also it is very easy to crack plastics with a heavy hand.
    I know this may sound a bit overkill, but compared to fixing or replacing Japanese switchgear it was way more complicated.
    But I am happy with the result. Should last for a few years?
  13. #13
    Join Date
    Oct 2004
    Northampton
    Posts
    1,053
    Quote Originally Posted by Nice 'n' Fat View Post
    I'm about to get my RH switch replaced (2009 K1300GT) - Dealer said no automatic replacement, they might get goodwill if they claim but since I have Extended Warranty (with £100 excess) BMW will not contribute! Not happy. Same when the rear wheel bearing failed at 10K miles.
    Whatever, my bike's still got better top-gear roll-on than a K1600
Posting Permissions
  • You may not post replies
  • You may not edit your posts
