Results 1 to 5 of 5
Thread: BMW navigator 5 help
  1. #1
    Join Date
    Feb 2015
    United Kingdom
    Posts
    79
    I've tried planning routes in 2 ways:
    - putting a final destination in, then adding other towns into the active route. This way if i bypass a town centre on route it keeps trying to route me back to the town centre I've missed i.e. If I want to go a to c via b it keeps sending me back to b until I reprogram the route
    - using the app function to put in towns a, b, c. However, this way it asks me to put in a specific street, which most of the time I don't know, so I end up guessing and getting the same re-routing issue as above
    I don't really want to plan routes in advance on a laptop. Really just do on the fly on the unit itself
    What's the best way? I think you may be able to tell it to ignore destination b once you get close and carry on to c? (Using example above)
  2. #2
    Join Date
    Nov 2005
    Newbury, Berkshire
    Posts
    11,088
    Blimey, your Sat Nav is shit ....... It can't even direct you to the correct forum
    http://www.ukgser.com/forums/forumdi...hp/46-GPS-Info
    2016 BMW R1200 GS Triple Black
    2017 BMW R Nine-T Scrambler X
    1962 BSA Gold Flash
    1980 Kawasaki Z1300
    2006 Suzuki GSF 650
    2003 Sherco 250
    2012 Triumph Bonneville
    2002 Triumph Bonneville (Desert Sled)
    2003 Triumph Daytona 955i (Rob North Replica)
    2001 Yamaha T-Max Mk1
    1979 Yamaha XT500
  3. #3
    Join Date
    Oct 2005
    Wapping, London
    Posts
    44,606
    The towns you are entering are waypoints, that is why the device is sending you back through any you miss.
    There are several ways to avoid the problem, maybe the easiest is to use the skip function. For example:
    A to E via towns, B, C and D
    Ride off on your way, following the route A to B. Go through B and all is so far well. Get bored, so you decide to miss out C and go straight to D. Push the skip button and the device will recalculate you through to D and then on to E.
  4. #4
    Join Date
    Feb 2015
    United Kingdom
    Posts
    79
    thanks - sounds like that's what I'm looking for. Easy when you know how!
  5. #5
    Join Date
    Aug 2012
    Sometimes here, sometimes there...
    Posts
    1,214
    There's a setting to add the "skip" button to the map screen...
Posting Permissions
  • You may not post replies
  • You may not edit your posts
