Results 1 to 10 of 10
Thread: Desert Fox 12v compressor
  1. #1
    Join Date
    Jul 2012
    London
    Posts
    1,644
    I'm toying with the idea of buying one of these 12v compressors to carry on they bike.
    It's from bikegear.co.za
    I've found others out there which 'look similar' but don't match up to the spec of this Desert Fox item, which really seems good. Bikegear has kindly gotten back to me with a quote to ship to me in the UK. But when shipping is added, it's all looking a bit pricey.
    Is anyone familiar with these particular compressors? I'd be interested in some feedback before i forked out.
    Alternatively, anyone commuting to SA that could pick one up for me (for a reward of course)?
  2. #2
    Join Date
    Jul 2012
    London
    Posts
    1,644
    No one?
    Looks like I might just have to take the plunge without any feedback...
  3. #3
    Join Date
    Jan 2009
    Co. Meath Irish Rep.
    Posts
    5,482
    It seems a long way to go for a pump. Most of those are the same item dressed up in the vendors own plastic casing. None will work off the BMW standard socket. I've broken out a few and fitted crocodile clips to a lead. They then wrap up very small. There are numerous sellers of pumps out there try eBay or amazon. If you google the item you might get some customer reviews. Personally I would be looking to buy nearer home. JJH
  4. #4
    Senior Member
    Join Date
    Nov 2004
    Newport UK
    Posts
    581
    Quote Originally Posted by JJH View Post
    This one works off standard BMW plug!
    http://www.adventurebikeshop.co.uk/d...micro_inflator
  5. #5
    Join Date
    Jun 2012
    derby england
    Posts
    1,909
    i can recomend the one made by ring, if you were to search a couple of my ride reports you will see why, i think i must have used it a couple of dozen times while on holiday and its never let me down. cost as i remember was around £10
    Sorry my mistake it is a wilko one that is the same as the earlier ring ones.
    http://www.wilko.com/car-care-produc...k/invt/0120244
  6. #6
    Join Date
    Jan 2009
    Posts
    5,482
    Quote Originally Posted by ianm00 View Post
    Interesting. Have you tried one? According to the specs. 4.5 amp to 40 psi. 5 amp trips the bmws fuse. I'll put one on my wants list. JJH
  7. #7
    Senior Member
    Join Date
    Nov 2004
    Newport UK
    Posts
    581
    I have one and so far it has worked ok with my R1200GS LC for topping up tyre pressures without any problems.
    Ian
  8. #8
    Join Date
    Jan 2009
    Posts
    5,482
    That's great. Thanks. Ordering one soon. JJH
  9. #9
    Senior Member
    Join Date
    Nov 2004
    Newport UK
    Posts
    581
    Its actally very good and also very small so keep in topbox on bike. I actually bought mine from http://www.sportouring.co.uk/ slightly better price and I also live close so was able to go and collect it.
    Ian
  10. #10
    Join Date
    Jul 2012
    London
    Posts
    1,644
    Thanks for the feedback!
    JJH. You're probably right, the option from SA is probably a bit over the top.
    But the spec is good and the unit seems to be serviceable, which means it should be the last one I buy (famous last words ).
    The cheap little units described are, I agree, incredibly cheap for what they are. But they take an age to fill a tyre from zero and I bet they are red hot by the end of it?
    But I'm still thinking..
Posting Permissions
  • You may not post replies
  • You may not edit your posts
