Results 1 to 13 of 13
Thread: Goldwing Non Starter
  1. #1
    Join Date
    Aug 2005
    Northern Ireland
    Posts
    875
    Went to start the Wing , plenty of battery strength but no go . Any thoughts? It's in neutral but would it be stuck in gear while sitting. Any advice would be great
    If you want the best seat in the house move the dog
  2. #2
    Join Date
    Oct 2016
    somewhere in time or Musselburgh
    Posts
    2,245
    You have tried rocking it back and forward, in gear, to turn engine over ?
    I think more info will be needed ie 1000/1100/2200/1500/1800 does it turn over ? Is it sparking, what about fuel.
    Having never done this myself obviously, the kill switch is set to run ???
  3. #3
    Join Date
    Aug 2005
    Northern Ireland
    Posts
    875
    It's 1500 , I did check the kill switch, will need to strip the Tupperware but I have no room to move , it's a tight squeeze with the GS . If I push it out I won't get her back in , that's why I have the reverse gear , let it do all the hard work.
  4. #4
    Join Date
    Jan 2009
    Co. Meath Irish Rep.
    Posts
    5,203
    Have you tried pulling in the clutch? JJH
  5. #5
    Join Date
    Aug 2005
    Northern Ireland
    Posts
    875
    Yes , tried that ..
  6. #6
    Join Date
    Jun 2006
    Islandmagee, Co Antrim NI
    Posts
    9,529
    Okay What actually happens when you press the button?
    Oh Great and Wise Deity, Grant me the serenity to accept the things I cannot change,
    Courage to change the things I can! And the wisdom to know the difference!
  7. #7
    Join Date
    Aug 2005
    Northern Ireland
    Posts
    875
    She turns over but that's it . Would a blown fuse stop her starting?
  8. #8
    Following a new path Click here to find out how to Subscribe
    Join Date
    Jan 2008
    Clarity
    Posts
    15,693
    Side Stand Switch?
  9. #9
    Join Date
    Jun 2006
    Posts
    9,529
    Okay Geno Yours is a GL 1500/6 isnt it
    Its still a Carburettor model?
    Have you the Choke on?
    Dash Lights ?
    Neutral Light ?
    Kill Switch In Run Position?
    What happens if you click sidestand up or down?
    Ah Yes Now I remember These have a Diaphragm Fuel pump don't they ? Can you hear it pumping when ignition is switch on ?
  10. #10
    Join Date
    Aug 2005
    Northern Ireland
    Posts
    875
    Tried choke on and off , all the lights are on , in neutral. Only thing is sidestand . Havnt tried that one or fuel pump priming. Not sure when I will get time . Thank you again.
  11. #11
    Join Date
    Jul 2012
    Lancs UK
    Posts
    976
    So its turning over but not firing...?
    How long since it was last run?
    How old is the petrol?
    If it has carbs and the usual Honda fuel pump setup run via a relay, the pump won't run until the engine actually runs (or at least cranks).
    Drain the carbs, use a jumper wire from the battery to the fuel pump + feed to prime the carbs & see if that does it.
    FWIW I prime the carbs on any bike that has stood a while, wether pumped or gravity fed.
  12. #12
    Join Date
    Aug 2005
    Northern Ireland
    Posts
    875
    So after some fiddling ,,some kicking the ground , over night on the charger , the big so and so fired up on 2nd push of button . Ran perfect , that big lump . But happy that she is running , now to get her out into daylight and to local spanner monkey for a set of new head bearings . Many Thanks for help .
  13. #13
    Join Date
    Sep 2012
    Torbay, England
    Posts
    27,296
    My Divvie 900 would turn over on a battery with a dead cell. It was a bit slow (so there was a clue) but it turned nonetheless.
    However at low system voltage the sparks igniters box won’t work same with fuel injection ECU if it’s posh.
    Charging the battery being enough to get it going suggests you’ll be needing a new one soon.
    08 R1200GSA
    76 Suzuki GT750
Posting Permissions
  • You may not post replies
  • You may not edit your posts
