Since the dreaded brake failure last year I have finally got round to investigating the ABS/Servo module itself.
First I tried all the usual:
Check brake lever switches - both OK.
Check wheel sensors - all OK.
Check wiring - all OK.
Flushed system through with new brake fluid - no difference still getting brake failure.
So before going with the servosectomy decided to remove the ABS/Servo module and take a look to see if anything was fixable.
Once out I checked the pressure relief valves as instructed here: http://forum.hexcode.co.za/forum/index.php?topic=4.0 - these seemed OK to me. I then checked the filters as described here: http://www.ukgser.com/forums/showthread.php/254381-A-simple-fix-for-some-brake-servo-problems?p=2601718#post2601718
I took the unit apart as far as I could. At the back of the unit there is a plate with two pressure switches inside bolted on:
It looked fairly grubby in there so I cleaned it up and noticed one of the switches had a hairline crack which then came apart when it was touched so I'm guessing this is my problem:
I have had a good Google around and can't find anywhere to get these switches.
I don't suppose anyone on here knows where to get some from?
If not I'm guessing next step is Servosectomy or get another complete unit from somewhere and hope it's switches are good.
