Results 1 to 9 of 9
Thread: XT Serow 225
  1. #1
    Join Date
    Feb 2017
    Scarborough
    Posts
    18
    XT Serow 225
    Anyone on here got a Serow 225? I have one for off roading but can't seem to get the carb set up right, the plug is always black and it rides lumpy. Any ideas on jetting etc appreciated.
    Thanks Andy
  2. #2
    Check the choke''s not stuck.
    KEA
  3. #3
    Join Date
    Jul 2010
    Overland and classic,vale of belvoir,Melton Mowbray
    Posts
    4,481
    Blocked emulsification tube
    The brass tube that the main jet screws into.
    Also the air drilling that supplies it in the mouth of the carb
    overland and classic
  4. #4
    Join Date
    Feb 2017
    Scarborough
    Posts
    18
    Thanks chaps, will take a look at those
  5. #5
    Say little, observe all spectator. Click here to find out how to Subscribe
    Join Date
    Jan 2001
    Shropshirington
    Posts
    14,112
    Not related but you might like to know.
    One of my Serrows was a right b'stard to start if left for 3 weeks or more. It turned out to be the fuel in the carb was losing its volatility. The simple solution was to drain the float bowl with the fuel tap turned off, once empty tighten the drain screw and open the fuel tap and it used to fire first touch of the starter then.
    I have an old lawn mower that does exactly the same, I suspect today's fuel is not of the same quality as it used to be.
  6. #6
    Join Date
    Nov 2005
    Newbury, Berkshire
    Posts
    12,397
    Or you could just do what a mate of mine used to which is to turn the fuel tap to off about one mile from home and by time he was pulling in to his driveway the bike was running on fumes
    Different method, same result without the faffing and stink of petrol all over your hands
    2016 BMW R1200 GS Triple Black
    1980 Kawasaki Z1300
    2002 Triumph Bonneville (Desert Sled)
    2017 Triumph Bonneville Bobber
    2003 Triumph Daytona 955i (Rob North Replica)
    1979 Yamaha XT500
  7. #7
    Join Date
    Jan 2001
    Shropshirington
    Posts
    14,112
    I used to do that too.... when I remembered
  8. #8
    Join Date
    Jul 2015
    Valhalla
    Posts
    70
    Xt225 bogs down under load. Not rideable. I think it may be the CDi unit.
    I understand they are hard to find. Does anyone know of suitable replacement unit?
  9. #9
    Join Date
    Jul 2015
    Valhalla
    Posts
    70
    Click here to find out how to remove these ads
    Quote Originally Posted by Brooklyn View Post
    Got one, hopefully that will sort it. Fowlers Yamaha, back order from Japan, should anyone need one..
Posting Permissions
  • You may not post replies
  • You may not edit your posts
