Results 1 to 5 of 5
Thread: Improved comfort
  1. #1
    Senior Member Click here to find out how to Subscribe
    Join Date
    Jul 2012
    Cleadon village
    Posts
    328
    Improved comfort
    Bike R1200r 2011 classic.
    I have always felt a bit cramped on the bike. ( 6ft 32" inside leg ) Previous bike was a 2015 GS. So I treated myself to a foot peg lowering kit and a bar riser kit. NN supplied the goods and I fitted them this weekend. The foot peg kit came with a brake line extension. It said probably not needed. Well I thought I would try and persuade the brake line to accept its lower position. It seemed a bit much so I fitted the extension piece supplied. So it meant of course a bleed of the rear brake system. As its a none abs I did a complete flush, seeing I had to break the seal on the fluid I did the front as well.
    It didn't take long to flush the front, the discolouration in the front circuit was more pronounce then the rear. A ride out today provide the benefit of the mods.
    http://cycle-ergo.com
    The above link is a tool I found useful in deciding what route to take to improve my riding comfort. Hope you may find it useful as well.
    Just had another fuel strip fitted last week( warranty ) thats the third one. I think the R1200r is good value when you compare it against some of the other models with almost identical spec.
  2. #2
    useful link
    Thanks for the link quite useful.
    Clive
  3. #3
    Join Date
    Dec 2003
    The wilds of Cheshire
    Posts
    1,382
    Will look into that. I'm 33" inside leg and do find it a bit tight but have added a sheepskin cover to raise the seat a bit. Are you sure non ABS thought all Classics came standard with ABS?
    Money isn't everything.But it keeps the kids intouch
  4. #4
    Join Date
    Jul 2012
    Cleadon village
    Posts
    328
    Hi Ted, Yes no abs, no magic suspension, tyre pressure monitors etc. It has heated grips onboard computer the list stops there. I thought of the raised comfort seat, extra 30mm but the option of the foot peg lowering kit was less than half the price. If you want I can pm you a few photos.
    I got the idea of the bar risers from you some months back. Nice easy fit and no mods for the cables.
  5. #5
    Join Date
    Dec 2003
    Posts
    1,382
    Thanks Steve, got some bar raisers. Its my wifes bike so although I take it out to give it a run now and then. She is shorter than me so need to be sure she doesn't have any problems. Will have a look at the lower pegs and do some measuring.. Spent a few bob, as you do, swapping to alloys as wires a pain when punctured. So promised not to spend any more..
Posting Permissions
  • You may not post replies
  • You may not edit your posts
