690 Enduro brake pedal
Dansin
Ombersley
Is the pedal the same for every year and just the fixing bolt that's different?
The KTM fiche for my 2010 lists it as 7651305024401S and the later years it's 7651305024401. I wondered if the 'S' is superceded?
I fitted a Rally Raid pedal, it comes with a spacer for the bolt that attaches to the master cylinder. I seem to remember you only fit this spacer to the later bikes.
I might have that the wrong way round but it shows that there is a difference.
If you need me to i'll check.
Thanks, I'd seen the RR one which uses a different fixing. It was the oem one I'm trying to work out. Might have to go down to AMS and see if they can actually be helpful for once.
Update
Went to AMS. It was a bit like pulling teeth as per usual. The 2011> pedal works with an updated LH bolt and bearings etc for the earlier bikes. Not worth wasting money on when the Rally Raid pedal works out at not much more money.
