Page 1 of 2 12 LastLast
Results 1 to 16 of 30
Thread: Bluetooth Dongle For PMR446 Radio - Any Comments?
  1. #1
    Last Of The V8 Interceptors Click here to find out how to Subscribe
    Join Date
    Nov 2015
    Dublin
    Posts
    1,056
    I recently got an SMH-5, which will replace the Autocom system I currently use.
    So I'll then be able to use my phone, GPS, listen to music, and talk two-way with my mate, etc.
    But this means I can no longer use the job PMR446 radio to talk one-way to third parties.
    No-one seems to sell a bluetooth-enabled PMR446 any more, so the obvious solution is the Sena SR10.
    But as an alternative to the SR10 (€180 + the adaptor cable for the job Kenwood radio), I'm curious about this €110 Midland dongle:
    http://www.maplin.ie/p/midland-wa-bl...land-pmr-a40uz
    Any of you guys have any experience with it or similar?
  2. #2
    One of our IAM group Observers uses a similar thing for his Kenwood ,The one your have a link for is Midland radio Specific. They have different two pin adapters. You will also need a Blue tooth PTT to operate the PMR Radio.
    Thats a lot to connect up with a bluetooth link ! even more so when you put into the connection equation GPs,Music, Phone etc .....our guy had lots of drop outs when riding and it took him ages to pair the system together. He binned it and bought the SR10 ,never had a problem since
  3. #3
    New Member (less than 15 Posts)
    Join Date
    Nov 2010
    London, UK
    Posts
    3
    The SR10 is a good bit of kit, but be careful if you end up with too many devices paired to the headset. You can have (at least on the 20S) a max of two devices paired at once - so if you have a GPS, a phone and the SR10 then you've got to pick one to unpair.
  4. #4
    Join Date
    Feb 2010
    Nearby
    Posts
    748
    This is great timing, was just wondering how I could get my pmr connected up to my bluetooth setup
    My Setup :
    Schuberth SRC connected to Iphone and Garmin 590 LM
    Garmin 590LM should be able to be bluetooth connected to the PMR radio via SR10, unless SRC doesnt limit connections.
    RBW.
    "The fact is this is about identifying what we do best and finding more ways of doing less of it better" - W1A
  5. #5
    Join Date
    Nov 2015
    Dublin
    Posts
    1,056
    In my case, the usage will be either/or - the radio usage will be for one application, the bluetooth application will be for another.
    When using the radio for comms, I won't be using GPS or phone.
    For personal use, I'd be using just bt comms, GPS & phone (calls & music), and not the radio.
    The big fail with the SR10 for me seems to be its battery life - website says 3.5 hours. I could be needing it all day. And hard-wiring to the bike isn't an option.
    PTT isn't a requirement for me; VOX-only is fine.
    Maplin's description of the Midland G10 radio (for example) includes this line:
    "The radio has a 2-pin Kenwood style socket for optional headsets, earpieces and microphones."
    This suggests that that dongle - as it fits the Midland G10 - will also fit Kenwood radios, no?
  6. #6
    Join Date
    Aug 2012
    Sometimes here, sometimes there...
    Posts
    1,291
    I use Intaride BIRD-1 BT connector with my Kenwood PMR.
    Works fine. Bit bulky though...
  7. #7
    I use the SR10 linked to a Kenwood radio for work with no problems at all, battery life is never an issue and only charge for a short time every couple of days.
    It's also simple enough to charge on the bike whilst it's in use.
    KEA
  8. #8
    Join Date
    Feb 2010
    Nearby
    Posts
    748
    I just looked here, and it says 12 hours talktime, 10 days standby ? https://www.sena.com/product/sr10/#specs
    Be interested where you have seen 3.5 hours.
    RBW.
    Quote Originally Posted by PhaedrusMC View Post
  9. #9
    Join Date
    Nov 2015
    Dublin
    Posts
    1,056
    Quote Originally Posted by Timolgra View Post
    My application is on multiple bikes, none (bar my own) with power sockets.
    Quote Originally Posted by rainbow-walker View Post
    RBW.
    My mistake. On that same specs page, it lists charge time as 3.5 hours. I obviously mis-read things. 12 hours talk time is plenty impressive.
    So where should I be looking for an SR10 at a good price? Decent Irish online seller is €200, FC-Moto is €180. Any decent sellers out there doing them cheaper?
  10. #10
    Quote Originally Posted by sasquatch View Post
    Nope , you pair the phone to the GPs , then the GPs to you helmet , that's linked in as one pair then .
  11. #11
    Pretty sure the midland and kenwood have different pins ,even though they are two pins . Don't think they use comparable fitments
  12. #12
    Join Date
    Feb 2010
    Nearby
    Posts
    748
    Yes there are different types of leads, so need the right one for your radio, there is a list on Sena's website. I was recommended a 'Wouxon' PMR so need to check which lead (I think its the Kenwood one).
    I also wanted to check the difference between the sr10 and sr10i, and found the information below which is quite straightforward.
    Here is the difference between the SR10 and the SR10i.
    They are the same unit except for the accessories that come in each of the packages.
    The SR10 is for motorcycle and powersports. The SR10i is mainly for industrial use.
    The SR10i only comes with a belt clip and a USB charging cable.
    The SR10 comes with a mount for motorcycles, wired PTT and extension, USB cable, 3.5mm audio cable, cigarette charger, and belt clip
    If you're on a motorcycle, buy the SR10.
    rgds
    RBW.
  13. #13
    Join Date
    Jan 2014
    Berkshire
    Posts
    1,868
    Useful to know
    Which helmet headset are you using Tim?
    I'm thinking of moving away from Autocom wired system to a more portable set up.
  14. #14
    Join Date
    Nov 2015
    Dublin
    Posts
    1,056
    Quote Originally Posted by DC View Post
    What bearing would that have on music sound quality? I have my phone and GPS (Zumo 550) paired with my SMH-5, and the same music file sounds way better when played from my phone than from the 550. If phone is paired with 550, and then 550 paired with SMH-5, won't the music sound quality then be that of the 550?
  15. #15
    Quote Originally Posted by Toddmeister View Post
    Useful to know
    SMH10 use it every day for work Toddy.
    KEA
  16. #16
    Join Date
    Jan 2014
    Berkshire
    Posts
    1,868
    Click here to find out how to remove these ads
    Thanks Tim, that's exactly why I asked! If it works everyday for you at work it will be more than sufficient for my occasional use. I shall take a look at the SMH10 and SR combination
Posting Permissions
  • You may not post replies
  • You may not edit your posts
