After my previous "Servo ABS Unit parts?" I said I would start a new thread with my attempt to repair it so here it is.
I am not an expert in any of this - just thought trying to repair my unit will only cost me some time (although I might learn something on the way) and want to try before I go down the servosectomy route. None of it might work and I might end up with a servosectomy in the end but if I don't try I won't know. With this in mind any comments or suggestions will be more than welcomed - especially if you think I'm doing something wrong or being stupid with something
As in my previous thread I removed the ABS Unit and took it apart. I found the pressure switches on the rear of the unit badly gummed up and one of the switches broke when I tried to clean it:
So the very nice Dr Farkoff sent me a couple of used ABS units:
The one on the left looked identical to my R1200GSA one and the one on the right is off a R1150 I think but although it looks different a lot of the parts are the same.
I pulled the two sent to me apart and the pressure switches looked identical on all 3 units but the cleanest ones were on the R1200 unit sent by Dr Farkoff so will use this on mine.
Whilst pulling the units apart I noticed a lot of gunge and dirt inside them all but the pressure switches on mine were definitely the grottiest looking. I then decided it would do no harm to clean my unit out thoroughly so I pulled it apart as well:
I tested what I could as follows:
Servo motors - hooked up a 12V battery to each motor in turn and all seem to run smoothly from the 2 R1200 units but the ones from the R1150 units do nothing.
ABS Solenoids - I just measured the resistance of the coil - I got 1.5 Ohms on all 6 solenoids so I am assuming they are all good:
Float switches - on the R1200 units the plastic housing on top contains two float switches for the brake fluid level so using a meter I checked that they worked which they did on both units:
Filters - there are a couple of filters at the bottom of where two of the brake pipes are connected - I removed these and cleaned out the filters (one of mine was definitely grubby):
Pipes - there are a couple of little pipes that come out when you pull the unit apart and there was some crud in both of mine so gave them a good clean out:
At this point as I kept on spotting various bit crud and syrupy looking fluid in various corners of the unit so decided to take apart completely and clean everything:
For cleaning I used isoprop and wiped everything down to hopefully leave no traces of anything in the corners. I've put the bits in a warm dry room before putting it all back together at the weekend. All the mechanical components and o-rings etc. inside all of the units all seem to be in good condition so I am hoping it is just the dirt and gunge that builds up that kills these units (and the broken pressure switch in my units case) and it might all work again soon.
