Results 1 to 14 of 14
Thread: Nextbase Ride Camera
  1. #1
    New Member (less than 15 Posts)
    Join Date
    Apr 2015
    london
    Posts
    8
    I have been given a Nextbase Ride Camera as a present. Has anyone overcome the problems that I have with it?
    The mount to the bike is poor for security so I have looked at RAM mounts to be more secure but still security is an issue, I cannot leave the camera on the bike overnight, I have accepted that I will have to take it on and off as required.
    The hard wire kit has an advantage over other cams that are battery operated only, however, to remove the camera I need to disconnect the lead from the camera, easy enough. Once disconnected the power lead is exposed to the elements, Nexbase do not make a blank cap for it. Apart from a bag and an elastic band, has anyone overcome this issue?
    Nextbase technical teams answer is to look on amazon for a solution, I then emailed head office pointing out this design issue and said it could be easily sorted with a blank cap that screws onto the power lead probably for only a few pence, no reply.
  2. #2
    opinionated, me? Click here to find out how to Subscribe
    Join Date
    May 2005
    Kelsall, Cheshire
    Posts
    4,810
    Yes, I had similar issues to yourself, and received similar replies! I threw away the mount that came with it, and replaced it with a proper ram mount. I take the power lead off and just hang it over the mount pointing to the floor.
    Mark
    Just when you've got this rat race licked, here come faster rats!
  3. #3
    Join Date
    Jan 2014
    Gloucester United Kingdom
    Posts
    1,455
    This is what I have done........ http://www.ukgser.com/forums/showthr...e-Ride-Dashcam
    I made my own mount, but they can be purchased from here......... http://www.nippynormans.com/gps-acce...gs-lc-and-more
    If you want to change the thumb buckle screw for a hex drive machine screw, it's a 1/4" UNC thread.
  4. #4
    Join Date
    Apr 2015
    london
    Posts
    8
    Quote Originally Posted by earthmover View Post
    Mark
    Any problems with corrosion?
  5. #5
    Join Date
    May 2005
    Kelsall, Cheshire
    Posts
    4,810
    Not yet!
    Mark
  6. #6
    Join Date
    Mar 2009
    Sussex
    Posts
    392
    Is the camera still working for you? I have one and am having trouble with it saying 'SD card full' rather than just recording over the oldest data.
    Chris
  7. #7
    Join Date
    Apr 2011
    seaside, N Yorks
    Posts
    378
    Quote Originally Posted by gbmud View Post
    Chris
    My Chinese 'clone' camera suggests re-format card every month.
    Some cards don't like continual writing and over-writing, so re-format is a good idea.
  8. #8
    Join Date
    Mar 2009
    Sussex
    Posts
    392
    Cheers. The problem will manifest within a couple of days riding, and expecting the user to reformat that often seems to defeat the point of 'looped' recording! Nextbase is a premium product and I was hoping for a seamless £200 experience rather than a (no offence, I think you have probably done better then me!) £15 eBay cheapie!
    Thanks for the thought though.
    Camera is presently with Nextbase, who cannot replicate the fault in their workshop. I plan to suggest they take it out on a bike!
    Chris
  9. #9
  10. #10
    Join Date
    May 2005
    Kelsall, Cheshire
    Posts
    4,810
    Sorry, missed earlier posts. Yes, my camera is still working perfectly. I did put a new SD card in it after recording an accident on it (not me, see "Ill fated Alps trip") which I didn't want to lose the footage. Never had the SD card full message, but I do format them regularly anyway on advice from a camera nerd. Hope you get yours sorted.
    Mark
  11. #11
    Join Date
    Jan 2014
    Posts
    1,455
    I took my sd card off the bike to find that not all rides are videoed.
    Anyone else have footage missing ?
    Cure found ?
  12. #12
    Join Date
    Mar 2009
    Sussex
    Posts
    392
    In light of the report on Amazon I have asked Nextbase for the camera to be returned so that I can get a refund.
    Chris
  13. #13
    Join Date
    May 2005
    Kelsall, Cheshire
    Posts
    4,810
    Quote Originally Posted by Gargy View Post
    Cure found ?
    Have you noticed that there is a file for "locked" recordings?
    Mark
  14. #14
    Join Date
    Jun 2011
    Surrounded, Staffordshire
    Posts
    1,714
    Click here to find out how to remove these ads
    formating: When you format the card in a camera and it takes less than 30 seconds, it is not really formating. What it is doing is erasing the fat table, ie. the index, list of contents etc.
    If you want to format it properly, place the memory card (may need an adapter) and place it in your computer. Select format from the computer, usually have the option of a deep or full format. This will take up 30 minutes depending on size and writes all over the memory space, checking for errors and recording them in its newly created fat/index table. This is the only way to ensure integrity of your memory card.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
