Results 1 to 2 of 2
Thread: Fe350 intermittent fault
  1. #1
    Join Date
    Jul 2008
    Cheshire
    Posts
    749
    Bike running sweet as a nut then just dies, flick the kill switch on and off and hit the starter and it fires up, runs for a little while then repeat procedure. Interval in between this happening gets shorter. Had this on a couple of occasions, feels like a fuel fault, last time was diagnosed as faulty voltage regulator. Three months on 59 hours and the same thing, no fault codes, both in line an in the tank fuel filters changed, injector and throttle body cleaned though not really dirty. So any ideas what could be causing it, anyone had similar issues?
  2. #2
    Well my educated guess would be the voltage regulator if that was the cause last time
    If it's failed again so soon you need to know why, so I'd be looking at the stator and connectors, battery, possible the ignition pulser ....
    They're a mystery when they go bad, you probably know KTM couldn't fix Amanda's newish bike.
    KEA
Posting Permissions
  • You may not post replies
  • You may not edit your posts
