Results 1 to 2 of 2
Thread: Rough running wr250
  1. #1
    Join Date
    Jun 2012
    Local
    Posts
    357
    Rough running wr250
    A bit of advice if poss, I have a WR250F 2004 which has a stutter right through the midrange in all gears. I have tried it running on choke to see if its full but my mechanic and the local yamaha dealer both think its ignition. I have heard that this is a common fault caused by the ignition coil bit as its an expensive test to buy I thought I would ask the collective on their views.
    Fuel is new, carb has been cleaned and new jets and needle fitted, valve clearances shimmed and timing checked.
    Ta
  2. #2
    Join Date
    Aug 2008
    Lincoln
    Posts
    5,327
    Blog Entries
    1
    Have you tried a new plug?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
