Page 1 of 2 12 LastLast
Results 1 to 16 of 17
Thread: Touratech topbox rework
  1. #1
    Join Date
    Feb 2012
    Lincolnshire
    Posts
    1,243
    I recently bought a Honda 250 CRF trail bike and decided it needs some storage for odds and sods- I don't like the idea of a rucksack so a topbox it has to be. It was perfect timing when a roadkill touratech box appeared on here at the right price and got things moving- thanks Reg
    I bought a rack off ebay.. which proved to be poor quality and did not fit the bike. After learning that the Honda official rack isn't suitable for a topbox I decided I would have to splash out on an aftermarket one which, contrary to BMW practice, are more expensive than the genuine Honda ones. That was the plan anyway, more on the rack later..
    Right then- the box arrived and was in reasonable condition considering it had been 'down the road' but both locks were in a bad state after being drilled etc by the police to try and establish who it belonged to.
    It was offered up top the bike and proved to be a bit too big for the little CRF.
    Attached Images Attached Images
  2. #2
    Join Date
    Feb 2012
    Lincolnshire
    Posts
    1,243
    Off with his head...
    Decide to shorten it down by cutting a section out of the middle to give it dimensions similar to Pelicase etc.
    Removed 12 cms out of the height- this was as much as needed and as much as was possible before the hinges had nothing to fasten to.
    First - lid off, followed by the sealing strip(needed heat to soften the adhesive), marked it up for the cut and also the height of the lid when refitted. Then attacked it with the jigsaw- touratech fetishists look away now..
  3. #3
    Join Date
    Feb 2012
    Lincolnshire
    Posts
    1,243
    lid off , lid on
    Refitted the lid and sealing strip, easy peasy because the lid sits tight on the seal making a good template.There is also the metal band around the inside edge which sits up to the seal and gives a good template for the bolts to be refitted.
    Remembered I had a Cymarc rear seat plate for my GS which I never got round to fitting...so offered this up to the bike and decided to use it instead of spending any more dosh.
  4. #4
    Join Date
    Feb 2012
    Lincolnshire
    Posts
    1,243
    Brackets next
    Knocked up some brackets and fitted the plate using the bolts and spacers in the cymarc kit, along with the tophat spacers that were on the original Honda bolts to protect the plastics.
    Also rebuilt the lock unit for the lid and recoded it to a spare bmw key so now it locks properly
  5. #5
    Join Date
    Feb 2012
    Lincolnshire
    Posts
    1,243
    Job done.
    Bolted it on. Plate maybe a bit on the big size but necessary to span the gap between the brackets. Could be used as Hooters intended by removing the box and fastening stuff direct to the plate.
    Job Done... apart from maybe painting or covering the brackets in carbon wrap or similar to tidy them up a bit.
  6. #6
    Join Date
    Jul 2010
    Overland and classic,vale of belvoir,Melton Mowbray
    Posts
    4,276
    Job done
    Just a thought,you might want to consider doing something with those leading edges,
    May well cause you some damage if you got shunted from behind
    overland and classic
  7. #7
    Join Date
    Dec 2008
    Rugby, Warwickshire
    Posts
    127
    Well done, mate. Nice job.
  8. #8
    Oh Yes.... Click here to find out how to Subscribe
    Join Date
    Oct 2006
    Earth
    Posts
    31,196
    Quote Originally Posted by RobA View Post
    +1
    Amazing what can be put to good use instead of the trash can....
    Perfekt ist nicht gut genug.
    UKGSER-A place where I've wasted so much time, learned so much, laughed a lot and cried a few times.
    Every bed of roses has pricks in it!
  9. #9
    Join Date
    Feb 2012
    Lincolnshire
    Posts
    1,243
    Quote Originally Posted by mikeyboy View Post
    Job done
    Cheers mikey- good point. I have a tooltube that was intended for the front but it's a bit long between the fixing points. That can be my next mini mini project.
    I cut the outside down to make it smaller ....And then start adding bits to the outside..Hmmm, analyze that
  10. #10
    Join Date
    May 2010
    Falkirk, Scotland
    Posts
    1,930
    Ace job, I asked Touratech rep at the Scottish show what the 25L aluminium topbox cost - £425
    Almost identical to your good effort.
    Mind I did go for this on My Tiger 800 - £19 from Farnell components
  11. #11
    Join Date
    Feb 2012
    Lincolnshire
    Posts
    1,243
    Quote Originally Posted by mcinlb View Post
    That looks tidy- big enough for a few bits and bobs, waterproofs etc.
  12. #12
    Join Date
    Feb 2012
    Lincolnshire
    Posts
    1,243
    Mk 2
    Mikeyboy got me worried after making the valid point about the leading edges.... So I removed the CYMARC plate and bolted it directly onto the brackets.
  13. #13
    Join Date
    Apr 2016
    Hamps Wilts Berks Triangle
    Posts
    145
    Oh that look good. What it's called / part number. Thanks
  14. #14
    Join Date
    Aug 2007
    Essex/Suffolk boarderlands
    Posts
    2,699
    Quote Originally Posted by w-w View Post
    I was interested too so looked and found this , looks similar.
    http://uk.farnell.com/unbranded/wate..._MostPopular_3
    <img src=http://www.ukgser.com/forums/images/smilies/motomartin.gif border=0 alt= title=Motomartin class=inlineimg />
  15. #15
    Join Date
    Dec 2009
    Canterbury, Kent
    Posts
    7,763
    Quote Originally Posted by steadysteve View Post
    That's a very nice piece of handy work Steve......
    Bounce
    KTM 1290 Super Adventure
    KTM 400 EXC
  16. #16
    Join Date
    Feb 2012
    Lincolnshire
    Posts
    1,243
    Click here to find out how to remove these ads
    Quote Originally Posted by Bounce View Post
    Thanks bounce-- I have since replaced it with a pelicase, bought from NuttyGSer, and a tooltube.
    The box is now fitted with some homemade brackets on the bottom to allow it to mount on a givi plate on my GS- ideal for its intended use i.e. odds and sods for a day trip.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
