Results 1 to 11 of 11
Thread: Bar risers
  1. #1
    Join Date
    Aug 2016
    KENT
    Posts
    5
    Bar risers
    Has anyone fitted Touratech 15 mm bar risers to a gsa/lc
    Touratech say no cable adjustment needed? Any info ?
  2. #2
    Join Date
    May 2014
    Downpatrick, N Ireland
    Posts
    784
    I've fitted 20mm risers to mine. No problems with cables or anything.
    Makes it a much nicer riding position.
  3. #3
    Join Date
    Aug 2016
    KENT
    Posts
    5
    Thanks John . Will go ahead and order them .
  4. #4
    Join Date
    Jan 2017
    Huntingdonshire, England
    Posts
    471
    I fitted 20mm risers today - no problems with cables etc.
    I managed to drop one of the large washers on the underside of the bar nut & it's vanished. I've ordered a new one but I'm more worried where the old one is & what it's going to do on it's way out........ So keep hold of all the bits when you're removing the nut on the underside.....
    D
  5. #5
    Join Date
    Aug 2016
    KENT
    Posts
    5
    Thanks Chalky mine have been delivered today so will watch out for that , hope it turns up somewhere with no harm done !
  6. #6
    Join Date
    Jan 2017
    Posts
    471
    Sorry - just re-read your OP, mine is an F650GS, so probably not relevant!!
    D
  7. #7
    Join Date
    Aug 2016
    KENT
    Posts
    5
  8. #8
    Join Date
    Nov 2006
    waitrose Brighton,England
    Posts
    5,587
    25mm risers on mine , very easy and no cable problems
    You Soft Southern Jessy
    My Glass is half Full
  9. #9
    Join Date
    Aug 2016
    KENT
    Posts
    5
    Thanks mate , they're on now with no issues , and better handling for me
  10. #10
    Senior Member
    Join Date
    Oct 2005
    wales
    Posts
    144
    About to fit wunderlich risers this weekend. Should increase height by 40mm. Hope the cables won't be an issue..
  11. #11
    Senior Member
    Join Date
    Jun 2016
    Warwickshire
    Posts
    190
    I fitted the up and macs Wunderlich risers, no problems with cable, you just have to change the attachment point of one cable, for which instructions are provided.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
