Page 1 of 2 12 LastLast
Results 1 to 16 of 23
Thread: Innovv K1.
  1. #1
    Rum Bosun Click here to find out how to Subscribe
    Join Date
    Mar 2017
    Pewsey, Wiltshire
    Posts
    278
    Innovv K1.
    I failed to get any replies to my previous post on this camera system so I went ahead and fitted mine in the way that seemed best and easiest... Though I MIGHT revise things in time.
    My bike is a 2017 GSA LC Triple Black.
    The Front camera I mounted on a custom made bracket above the headlight. I considered buying a bracket to fix the camera on the indicator stub, but I wanted to get a centre line POV in the shot... AND as I already had a sheet of 2mm aluminium, it cost me only the time it took to make.
    The rear cam, I mounted on the rear near-side indicator stalk... that way it "shouldn't" get too dirty from the exhaust - HOPEFULLY!
    I covered the openings on the GPS aerial with "transpa-seal" (Clear sticky-backed-plastic) and I've set that in the front right of the fairing.
    I removed the centre section of the tank cover (2 x T25, 1 T30 bolts at the very front, 2 x T25 in the coin tray & 2 x T25 at the very rear of the tank cover - it then un-clips quite easily from the rear) I ran the wire from the camera along the left side weld of the tank seam, the GPS wire ran along the opposite side.
    For now, I've mounted the DVR unit under the pillion seat, "waterproofing it" with a heavy duty clip-seal poly bag. To save the LCD screen getting dinked, I taped two pieces of UPVC plastic across the top.
    I used the supplied 5V power converter, also fixing that under the pillion seat. All wires going to the DVR unit were fitted with ferrous ballast units that I bought on e-Bay. The trigger for the power supply was taken from a PDM60 unit that I fitted.
    I have had to re-programme the DVR unit to recognise that the cameras have been "flipped" but that was pretty simple to do - even though the instructions that come with the camera system are near non-existent.
    Tomorrows commute will be the proving ground for how the cameras perform on the home-made brackets... but I'm fairly confident they'll be OK.
    I didn't bother with the supplied switch to control the cameras as I want them recording all the time.
    Would I recommend this system? YES - as it's cheaper than many, unobtrusive and it covers front AND rear views.
    Attached Images Attached Images
  2. #2
    Join Date
    Jun 2012
    derby england
    Posts
    1,901
    be interested to know if you get any jello efect on the video due to vibes.
  3. #3
    Join Date
    Mar 2017
    Pewsey, Wiltshire
    Posts
    278
    I'll let you know
  4. #4
    Join Date
    Aug 2014
    Barrowford Lancastershire
    Posts
    1,053
    Where did you buy it from? I've been looking at the C3
    Out on the floor - K.T.F.
  5. #5
    Join Date
    Sep 2009
    East Grinstead
    Posts
    365
    Do let us know how you get on with this.
    I have had one for over a year now. When it works it's very good quality. But it frequently locks up and overheats. Daily resets and reformats seem to work but the saved files will eventually stop it overwriting.
    Great price and customer service. Once it is fitted you (should be ) able to forget about it unless you need to access a file.
    And it is discrete.
  6. #6
    Join Date
    Mar 2017
    Pewsey, Wiltshire
    Posts
    278
    Quote Originally Posted by vRSG60 View Post
    Direct from Innovv
  7. #7
    Join Date
    Mar 2017
    Pewsey, Wiltshire
    Posts
    278
    I'm hoping it won't overheat.
    My secondary choice of positioning would be atop the ECU under the riders seat... But I thought that might actually be warmer.
    Not sure they sell the C3 anymore?
  8. #8
    Join Date
    Aug 2014
    Posts
    1,053
    There's a UK site got them for sale £102
  9. #9
    Join Date
    Sep 2009
    East Grinstead
    Posts
    365
    Do tell where please?.
  10. #10
    Join Date
    Aug 2014
    Posts
    1,053
    Quote Originally Posted by dmilne View Post
    Here.
  11. #11
    Join Date
    Sep 2009
    East Grinstead
    Posts
    365
    Ummm.. Thank you... not..
    This thread is for the INNOVV K1
    The link only has C3s.
    Thought it was cheap..
  12. #12
    Join Date
    Aug 2014
    Posts
    1,053
    The post above mine said he wasn't sure they sold the C3s anymore hence my link.
  13. #13
    Join Date
    Mar 2017
    Pewsey, Wiltshire
    Posts
    278
    Thanks anyway for the quote vRSG60... I might get one of those as a helmet cam!
    Quote Originally Posted by leedude03 View Post
    Leedude... Going to TRY to upload a front and rear view of part of my commute home. I don't think it's jello - despite the best efforts of the rural Wiltshire roads! The rear view cam IS covered in dirt so the picture quality isn't great. I'm wondering if cams that have given a "jello'd" effect were mounted on rubber "dampening"? My cameras are mounted without any rubber or foam
    I cannot work out how to upload video files. If you look on Facebook Group "Adventure Bike Trail Riding UK" I posted two videos _ Front & Rear POV
  14. #14
    Join Date
    Mar 2017
    Pewsey, Wiltshire
    Posts
    278
    And it is discrete.
    Having done some research on the lock-ups, it would appear that they are generally caused by RF interference. Fitting (as I have) ferrite ballasts to the wires all but negates this problem. As for the overheating, that is a problem that I've yet to experience. In the mean time, I'll keep looking to find a solution to either fix or pre-empt that problem
  15. #15
    Join Date
    Apr 2016
    Somerset
    Posts
    110
    I ordered one this week so hopefully next weekend I can spend trying to fit it. I have also read that rf is the most common cause of issues and easily sorted. I will upload some images and details once done.
  16. #16
    Join Date
    Mar 2017
    Pewsey, Wiltshire
    Posts
    278
    Quote Originally Posted by Sky Bear View Post
    I fitted these (http://www.ebay.co.uk/itm/2519682771...%3AMEBIDX%3AIT) to all wires. Not had an RF issue.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
