In addition to the above taster video.
The really clever bit is when you get it all back home.
Uploading BOTH front and rear camera footage directly into Garmin Virb Edit Software is very easy. It sorts out the links between the two video's and the Telemetric Data.
As soon as you select a video clip, it knows you have footage with the same date and time stamp, and asks you if you want to upload both files.
This means you can now mix and match your viewing angle from both front and rear camera.
So on screen you can have:-
1) Front Camera View only
2) Rear Camera View only
3) Front Camera View with Rear Camera view (Picture in Picture and placed anywhere on the screen)
4) Rear Camera View with Front Camera view (Picture in Picture and placed anywhere on the screen)
5) Front and Rear Camera View (Split half and half)
You can then select which camera audio you want.
You can then select which camera G-Metric data you want.
This is brilliant because you can only connect one Bluetooth Device to each camera. So in theory (I haven't tested this yet) but you could connect your OBD2 Data to front Camera, then Connect your Bluetooth Helmet microphone by Bluetooth to Rear Camera. So then you would have audio overlay, alongside telemetric data (all synchronised).
