Hi Folks,
just posting on here to see if anyone could shed some light for us...
Recently installed a new clutch friction plate, pressure plate and cover plate from Motorworks (with new pushrod/pushrod felt seal etc). Bought clutch alignment tool & used it during the work too. New bolts were used as required.
Since replacing all the above there have been issues with finding neutral whilst riding the bike. The clutch won't fully clear/release even with the clutch lever pulled fully back, it just never seems to totally disengage and there is constant drive to the back wheel whilst in gear.
We have bled the clutch numerous times and the lever itself feels great to operate. The lever is not fouling the hand guard.
We have replaced the slave cylinder to see if that was an issue but it has made no difference.
We have added a washer to the end of the pushrod to see if the extra 2mm will make the clutch clear but again it has made no difference.
Would like to not have to split the bike again if possible and thats what brings me here to see if anyone has had a similar issue in the past? Are we missing something fairly straightforward here.
The clutch hose appears in good shape & there are no leaks in the system, either master cylinder end or slave cylinder.
Hopefully i have explained the issue well enough, if not just ask away...
Thanks in advance,
Trev.
Thanks in advance,
Trev.
