Rather than update an old thread thought I would start a fresh one as I've tried everything to date with no success to find the electrical drain on my '08 GSA when the ignition is off. However, I'm wondering if I have stumbled upon the culprit. Having disconnected everything I can find to disconnect and wiring to check I had given up the ghost and resigned myself that a visit to a dealer will be in order. The bike runs perfectly, there are no fault codes showing from the GS911 but it still drains the battery by 0.4v every 24 hours. So over Easter I stripped everything off the bike to take it back to OEM spec as it will save the dealer from checking everything I have already done - and charging me for it.
However, I'm still using the bike in the meantime and wanted to power my Zumo 660 so bought the canbus socket from Nippy's to do just that. Wired up the Zumo harness tonight and plugged it into the canbus connector just behind the oil cooler. When I put the Zumo in the cradle however, and the ignition was off at this point, the Zumo powered straight up, not under battery power but from the Canbus live feed. Nothing changes with the ignition on, the zumo is still powered as it should be. When turning the ignition off, the Zumo stays powered up for about 60 seconds then I get the "powering off" notice and do I want to use battery power etc. If I do nothing, 4 seconds later the zumo goes back into powered mode. The zumo then just goes into a continual cycle of 60 seconds powered, 4 seconds on battery and then 60 seconds powered - all with ignition off.
Could this be the cause of the battery drain? I know the drain was happening without the zumo cradle plugged in but it seems to me that the canbus socket is being powered through this 60 secs on/4 secs off cycle continually irrespective of anything connected to it or whether the ignition is on or off. In order to do that the ECU must still be operating to some extent rather than off to sleep.
Anyone had this problem and know what the fix is? Simple ECU software update or a new ECU?
Forgot to add - if I turn the zumo off manually and with ignition off then it will power itself back up again and continue the 60 second cycle.
