Page 5 of 6 FirstFirst ... 3456 LastLast
Results 65 to 80 of 84
Thread: Schuberth C4 & SC-1 Comms
  1. #65
    rebircsbuS Click here to find out how to Subscribe
    Join Date
    Dec 2006
    The Home of Ferodo
    Posts
    2,373
    Quote Originally Posted by Arsey View Post
    I’m liking my C4 BUT the “pinlock” is utter shite.
    Have just been away and done 1000 miles in last few days and the bloody pinlock insert doesn’t seal at all.At one point I had a bug crawling between the insert and the visor !
    Will ring Pete at Just Helmets on Monday but has anyone else had issues with theirs ?
    Normally you can rotate the pin lock posts to make the insert seat better. Guessing it's the same on a C4.
  2. #66
    Join Date
    Mar 2008
    Guernsey or on another beach...
    Posts
    10,453
    Quote Originally Posted by DottyDog View Post
    I don't know what you mean by push them out? I don't mean to split hairs, but they looks like I might be able to pull them out if that's what you mean?
    Pins are fixed as far as I can see.Won't budge at all.
  3. #67
    Yes had similar though not as bad. I took the visor off yesterday to try and adjust the seal, which isn't a tight fit as y describe and even had a few droplets of water between the pinlock and visor. Tried the pin rotation but doesn't seem to do anything of notice.
    On a separate note I lost the Chin Vent Cover from mine which was kindly replaced by Tranam after speaking with Pete at Just Helmets. If you catch the vent side on when open the cover pulled off very easily. Have put the new one on with a dab of Super Glue on the 4 retaining lugs.
    Cars & Vans for a living, Bikes to feel alive!
  4. #68
    Join Date
    Mar 2008
    Posts
    10,453
    Quote Originally Posted by Jonno58 View Post
    Unlike the Shoei pinlocks,the one supplied with the C4 doesnt seem to have a sticky lip that grips the visor.I have always been taught to open the visor up as flat as possible then attach the pinlock insert then let it flex back to it's natural shape.
    With Shoeis,this forms a very strong seal and if you try and move the pinlock ,it won't budge,but with the C4 jobby,the insert doesn't grip the visor in the same way as the lip around the insert is just hard plastic and has no gripping qualities like the Shoei version.
    It's very poor for a very expensive helmet.
    As I mentioned above,I was riding along the other day and I had quite a big bug crawling on my visor.When I couldn't knock it off on the outside,I stopped to get it off the inside and still couldnt get to it as it was between the pinlock and visor !!!! The gap was about 8mm at the lower edge !!!
  5. #69
    Join Date
    Apr 2009
    DERBYSHIRE
    Posts
    3,020
    Quote Originally Posted by JoeC View Post
    They are really really stiff when they fit them at the factory, I used a flat coin to push out 'from inside' and rotate slightly to alter the cam on the pin and fit back.
  6. #70
    Pinlock Insert scratching top of the visor
    In relation to the loose 'Pinlock Style Insert' where it is loose it moves up and down and the ridge on the top of the insert has scratched the inside of the visor, see image, anyone else experienced this?
    Attached Images Attached Images
  7. #71
    Join Date
    Jan 2002
    In my woods, halfway up Ben Aigan, Moray
    Posts
    618
    Looks exactly like mine Jonno.
    In fairness, Pete from JustHelmets has said he will sort it, but he is away now for a couple of weeks.
    If you can't do it anymore, teach it
  8. #72
    Quote Originally Posted by The Stimulator View Post
    Cheers Stimulator, can you share Pete's view when he's got back to you. As has been said by others given the cost of these helmets it's a shame they've not sorted this before launch.
  9. #73
    Join Date
    Mar 2008
    Posts
    10,453
    Yes I called JH today to be told Pete was away.
  10. #74
    Senior Member
    Join Date
    Jan 2016
    Fife
    Posts
    338
    I'm curious ....Has anyone else found the C4 to be a lot tighter (fit) than the equivalent C3?
    I don't just mean "new-helmet tight " .
    I think I'm going to have to return my L for an XL .
    Annoying !
  11. #75
    Quote Originally Posted by Aberdeen GS View Post
    Annoying !
    I had to exchange from L to XL, several people have found this and there is another thread mentioning that subject here.
    http://www.ukgser.com/forums/showthr...017!!!!!/page4
    Hopefully from Just Helmets and you'll get great service!
  12. #76
    Senior Member
    Join Date
    Jan 2016
    Fife
    Posts
    338
    Yep ...
    If you are buying a helmet ...please speak to Pete .
    Superb guy . Great service.
    Jonno , I'd missed that .... thanks for the link
  13. #77
    Join Date
    Mar 2008
    Posts
    10,453
    Update on C4 visor/pinlock.
    I received a new visor and pinlock from Pete at Just Helmets today.The new one looks very solid and the pinlock is firmly in position ,unlike my original.
    Great service from Pete at Just Helmets,as always.The only guy I'll buy a helmet from these days.Brilliant service !!
  14. #78
    Join Date
    Oct 2008
    Drigdale
    Posts
    7,515
    Got mine today. Very impressed and at last I have tunes.
  15. #79
    Finally got to speak to Pete today after a bout of telephone tennis and he's arranging a new one to be sent to myself also! Happy Days & as you say great service from him!
  16. #80
    Join Date
    Oct 2008
    Drigdale
    Posts
    7,515
    Mine had it's debut run this weekend in a very mixed weather trip.
    The good.
    Faultless performance in the rain.
    Nice concealed comms kit.
    The bugs.
    I like to ride visor open. This keeps shutting in turbulence and so will need to investigate the O ring solution.
    Connectivity. It would connect seamlessly with the Gamin sat nav and my iPhone, but then had a tendency to drop needing me to go into the nav bluetooth menu to reconnect.
    Occasionally it put pressure on my bonce right on the top in the middle. Weird but seems to have gone now.
    Overall it's bloody expensive but I loved my C3 (which has died) and so moving on to the latest version was no option.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
