Page 1 of 2 12 LastLast
Results 1 to 16 of 17
Thread: Optimate 4 - use on a car?
  1. #1
    Join Date
    Nov 2016
    Ely
    Posts
    406
    As it says, can I use an optimate 4 to charge/recondition my battery in my car, using the croc clips?
    Any advice is welcome... and piss taking
  2. #2
    Join Date
    Dec 2004
    Oswestry
    Posts
    1,526
    Works fine on a car, left my Audi for two years, started first time on return.
    Forget all these Healthy Foods I need all the preservatives I can get!!!
  3. #3
    Join Date
    Jan 2009
    Co. Meath Irish Rep.
    Posts
    4,935
    Yes. JJH
  4. #4
    Join Date
    Nov 2016
    Ely
    Posts
    406
    Thnx fellas, much appreciated.. Al
  5. #5
    Member
    Join Date
    May 2012
    Brighton
    Posts
    69
    Works no problem on any battery that's 12 volt - my mini has a stop start funny (expensive) battery and initially it seems to confuse it but then it charges fine
  6. #6
    Join Date
    Nov 2016
    Ely
    Posts
    406
    Thnx BV, my battery had worn down, so my stop-start function wasn't kicking in... so just dying to boost it back up... on charge over night. Will let you know if it works out.
  7. #7
    Join Date
    Mar 2005
    SW
    Posts
    3,180
    Yes, recovered a dead, not even clickety click, 11 v , probably sulphated battery on my sorn'd car and battery still good and holding its charge. In fact 12.5 V (75%) when checked yesterday after standing for for 2 weeks, so very pleased. Optimate seems to have intelligently repaired the battery.
    Too shiny and clean to use it properly.
  8. #8
    Join Date
    Jul 2014
    Gloucestershire UK
    Posts
    2,146
    Quote Originally Posted by BigAlEly View Post
    I hate the start/stop function on my car and usually remember to turn it off when I start the engine. When I don't it always seems to cut out at the wrong time. Bloody dangerous in my openion and can't be doing the engine any good.
  9. #9
    Join Date
    Aug 2010
    Paradise
    Posts
    21,268
    Quote Originally Posted by SteveC10 View Post
    Agreed
  10. #10
    Join Date
    Nov 2016
    Ely
    Posts
    406
    I agree with you... mines a manual gearbox and there are times on the commute when it's fine to leave it in neutral and let the s/s do its thing, most of the time it's in gear so it never cuts out at the wrong time. My old man has a merc auto and it's a right pain on that...
  11. #11
    Join Date
    Mar 2005
    SW
    Posts
    3,180
    FYI . Stop Start on several new cars no longer uses a conventional , tooth wearing , starter motor ; the alternator has a built in cranking function , when demanded . Do you know how your stop start works ?
    Agree , it's usually an intolerable delay , but on one of my cars it's so fast in operation that it's actually not noticeable.
  12. #12
    Join Date
    Sep 2003
    Northumberland
    Posts
    5,520
    My Polo GTDI and the Corrado before it were toys that were only used infrequently, both had Optimate leads permanently fitted to the battery and were left on charge for weeks if not months on end without any problems
  13. #13
    Join Date
    Nov 2016
    Ely
    Posts
    406
    Yes, it worked well.. overnight charge and the car battery is 100% charged and the stop start worked instantly.
    Thnx fellas
  14. #14
    Join Date
    Sep 2003
    Northumberland
    Posts
    5,520
    On the wifes A3 went into the menu on VCDS diagnostic and turned off the stop start facility
    Thnx fellas
  15. #15
    Join Date
    Nov 2016
    Ely
    Posts
    406
    Quote Originally Posted by Neil W View Post
    didn't know you could do that... but I am happy with it as I spend quite a bit of my commute in traffic jams
  16. #16
    Join Date
    Jul 2014
    Gloucestershire UK
    Posts
    2,146
    Do you know if this can be done on a BMW Five Series? mine drives me nuts!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
