Results 1 to 8 of 8
Thread: D-ESA intermittent warning
  1. #1
    Join Date
    Dec 2015
    North Yorkshire
    Posts
    220
    My XR has started flashing up a "D-ESA" warning light, started as an occasional, split second warning. Took ages to figure what it said as it flashed so quickly. Its doing it more often now, anyone else had this?
    I've read of the sensor rod falling off the height sensor and making a permanent warning, I've checked mine and its fine.
    It may well be a trip to the dealer but if its an easy fix I could avoid that.
    Thanks in advance!
    "aint never not made it yet....."
    https://trevsfleet.wordpress.com/
  2. #2
    Join Date
    Dec 2015
    North Yorkshire
    Posts
    220
    Based on the control rod causing a full time fault, i've taken the plug off the hight sensor and given it a quick squirt with WD 40, at first glance seems to have cured it. Will report back after a proper ride out...
  3. #3
    Join Date
    Mar 2007
    East Yorkshire
    Posts
    2,085
    Quote Originally Posted by Bronco Jr View Post
    Where abouts is the height sensor? Any chance of a pic pose?
  4. #4
    Join Date
    Aug 2002
    Right here
    Posts
    6,122
    Thanks in advance!
    Do you jet wash the bike by chance ?
    Freedom of speech and thought matters, especially when it is speech and thought with which we disagree. The moment the majority decides to destroy people for engaging in thought it dislikes, thought crime becomes a reality.
    Ben Shapiro
  5. #5
    Join Date
    Dec 2015
    North Yorkshire
    Posts
    220
    Quote Originally Posted by iandavid View Post
    It's nestled in the swing arm next to the rear shock. Will take a pic this eve.
  6. #6
    Join Date
    Dec 2015
    North Yorkshire
    Posts
    220
    Quote Originally Posted by jetjock View Post
    No, never.
  7. #7
    Join Date
    Aug 2002
    Right here
    Posts
    6,122
    No, never.
    Ben Shapiro
  8. #8
    Join Date
    Dec 2015
    North Yorkshire
    Posts
    220
    Warnings all fixed.
    I thought I'd update this thread in case its of use to anyone in the future. The intermittent D-ESA warning issue expanded into an intermittent rev-counter and finally ABS and traction control warnings.
    I took the bike to AJ's this morning, I'd phoned ahead to tell them I was on a tight schedule, rolled up at 8.30 and they were ready for me. A nice cup of coffee later Dan came to tell me they'd found the battery terminal a little lose. They tightened it up for me and its as good as gold again. I didn't think of checking battery terminals maybe this post will save someone some time if they experience the same thing....
Posting Permissions
  • You may not post replies
  • You may not edit your posts
