Page 1 of 2 12 LastLast
Results 1 to 16 of 22
Thread: Filling in drill Holes in panniers
  1. #1
    Join Date
    Nov 2004
    Cork, Ireland
    Posts
    3,147
    Just converted my aluminium panniers to fit on Touratech rails, having been previouisly on H&B rails. Relocated the 15mm pucks and fitted 3mm spacers( acrylic discs with appropriate holes drilled) to adapt to the 18mm rails, I also changed over from self tapping screws to nuts and bolts with nuts being recessed ). I'm left with 12 small drill holes ( about 6mm) which were in old location of pucks. Was wondering how best to block/fill them. Some of the holes coincide with the rails so cannot be covered by anything more than a fraction of a mm thick on the exterior. Was thinking, Gorilla tape on inside then fill the 2mm thickness of the hole with epoxy followed by gorilla tape on exterior, or maybe no tape on exterior as epoxy is filling the hole. Anyone got any other ideas, originally I had been thinking of using some reinforced plastic film ( same stuff used in damp proof course in walls) stuck on with siome sort of adheisive, however the gorilla tape seems like quite tough sticky stuff.
    Recessed holes look rough in photo but will have filling of black silicone eventually. White layer is adhesive on both sides of spacer, probably overkill but easy to do.
    Attached Images Attached Images
  2. #2
    Join Date
    Oct 2014
    Lancashire
    Posts
    4,609
    10p coins stuck on the inside with Araldite.
  3. #3
    Destined to come last Click here to find out how to Subscribe
    Join Date
    Feb 2010
    'arrow, near the 'ill.
    Posts
    1,169
    Pop rivet and washer
    Brian
    GSA Triple Black
    VW 'Triple Black' Campervan
    Zagato Guzzi 950 cafe
    Guzzi Le Mans 2, black and gold Coburn and Hughes.
    You may say I'm a dreamer, but I'm not the only one
  4. #4
    Join Date
    Nov 2004
    Cork, Ireland
    Posts
    3,147
    Quote Originally Posted by Oldrat View Post
    I don't think they will work as it will be too proud with the rails sitting on the rivet.
  5. #5
    Join Date
    Nov 2014
    Dallas, Scotland
    Posts
    2,663
    Press in a bit of aluminium into each hole (just below the surface), a tight fit, and alu weld it from the outside and then grind / polish to a smooth finish.
    I've done it with stainless steel before so aluminium should be so much easier.
    "I must be traveling on now 'cause there's too many places I've got to see.
  6. #6
    Join Date
    Jan 2009
    Co. Meath Irish Rep.
    Posts
    5,071
    Duck tape each side. JJH
  7. #7
    Join Date
    Nov 2011
    Cheshire
    Posts
    1,457
    Pop rivets will not be waterproof. Use small pieces of cut aluminium glued in place, as mentioned Araldite works well.
  8. #8
    Join Date
    Sep 2003
    Northumberland
    Posts
    5,697
    Check out aluminium aircraft rivets on e bay , countersunk ones will be perfect
  9. #9
    Join Date
    Nov 2011
    Grantham, England
    Posts
    555
    As they are only 6mm dia holes it would be easy to weld them up and grind them flush without having to insert any plugs.
  10. #10
    Join Date
    Feb 2017
    Cardiff, Wales
    Posts
    510
    Tapered rubber bung, waterproof glue, pull through wait till dry, trim off.
  11. #11
    Join Date
    Dec 2015
    The Solent
    Posts
    174
    Ridiculous idea. You get much better coverage with a 2p. I know, used it on my Land Rover a few times.
  12. #12
    Join Date
    Mar 2009
    Worcs. England
    Posts
    3,007
    Rubber grommets, Screwfix or Halfords......sorted
  13. #13
    Join Date
    May 2010
    Wandsworth, London
    Posts
    2,901
    Park at top og waitrose/ and an void deep puddlrs?
    Sent from my SM-G920F using Tapatalk
  14. #14
    Join Date
    Apr 2017
    Manchester UK
    Posts
    2,661
    Slightly Bevel the outside and inside of the hole then fill with epoxy,sand and paint as appropriate. Some clear tape on the outside will help whilst it dries
    Caution : May stop suddenly
  15. #15
    Join Date
    Feb 2015
    Huntingdonshire
    Posts
    9,357
    Tape on the inside because if you weld the holes up you'll wreck the anodising.
  16. #16
    Join Date
    Jun 2011
    Windygates, Fife.
    Posts
    242
    Click here to find out how to remove these ads
    Quote Originally Posted by Andi_archer View Post
    I fixed 4 drilled holes on my metal mules like that, didn't bother painting them just put a sticker over the repair, totally flush.
    JimmyMac
Posting Permissions
  • You may not post replies
  • You may not edit your posts
