Results 1 to 3 of 3
Thread: YMaha YZF1000R Clutch Problems
  1. #1
    Join Date
    Jul 2014
    Gloucestershire UK
    Please could anyone who's had a similar problem to the one below and found a solution let me know how they overcame it.
    A friend has a Yamaha YZF1000R which suffers from clutch drag and is virtually impossible to get into neutral when stationary with the engine running.
    He's changed the whole clutch mechanism + because this didn't improve it the hydraulic pipe as recommended by someone who said they'd had a similar issue and this solved it. The oil is also fresh and is the correct grade, type etc for the bike.
    The leaver has resistance all the way so is moving the clutch but it's still dragging far too much.
    I read on the GS forum that someone cured their clutch problem by using different oil and not filling it more than half way up the sight glass.
    My GSLC gearbox and clutch spoiled the bike so much I sold it and I had tried this.
    Any tips or ideas to solve my friend's problem would be very much appreciated.
  2. #2
    Join Date
    Jun 2012
    derby england
    bent or warped steels or frictions, incorrect fitment, none genuine parts, wrong grade oil, week or faulty master or slave cylinder. there are many things that can cause this problem
  3. #3
    Join Date
    Nov 2003
    Dublin, Ireland
    Click here to find out how to remove these ads
    Had similar on a Honda.
    It was a bent pushrod.
    appears bright from a distance / dim up close
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Anyone attending a Ride Out or Event organised through the UKGSer Forums does so at their own risk. or anyone organising an event posted here will not be held responsible in any way for damage or personal injury sustained while attending any such events.
