Results 1 to 3 of 3
Thread: GS hand guards
  1. #1
    Join Date
    Dec 2003
    The wilds of Cheshire
    Posts
    1,389
    GS hand guards
    Fitted a set of GS hand guards to the R Classic some time ago. Kettle 738 just asked for info on how I fitted them so here we are.
    Looked at a few pictures of installations and not to happy with the end fitting so had my grandson make up some end bosses. Added a couple of torx bolts from EBay now looks like standard. Pictures show new and old large hole(GS) boss + bolt and couple of rubber washers to stop them twisting and fill the larger hole in the GS hand guards. Done at leased 6k miles so far without a problem. The bar clamps fitted without a problem just needed a bit of care and time to get just right position, one is a bit close to the master cyl but no problems.
    Attached Images Attached Images
    Money isn't everything.But it keeps the kids intouch
  2. #2
    Join Date
    Aug 2013
    Kent, England
    Posts
    142
    Many thanks for posting the photos.....they are worth a thousand words and pretty much exactly what I needed to see......time to get turning on the lathe and see if I can get anywhere close to your new spacers.
    Mick.
  3. #3
    Join Date
    Aug 2013
    Kent, England
    Posts
    142
    I fitted mine today, made up a pair of adaptors on the lathe which look uncannily like the ones in your photo and they are a pretty much perfect fit.....albeit the right hand side is a bit snug around the master cylinder, but with just enough clearance to be fine.
    A good and enjoyable job.
    Mick.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
