Page 1 of 2 12 LastLast
Results 1 to 16 of 21
Thread: Motorbike movers
  1. #1
    Join Date
    Jan 2008
    Sevenoaks
    Posts
    564
    Motorbike movers
    Does anyone have experience of motorbike movers? That's the trolley-with-casters gadget such as these:
    http://www.ebay.co.uk/itm/PDSCTR11-B...3D380724222919
    or these:
    http://shop.becker-technik.de/en/mot...as-gp-320.html
    The eBay item has 70mm wheels (of unknown material) whereas the Becker-tec's are 50mm and can be replaced with polyurethane versions
    TIA
    Richard
    Magma red R1200GSA, Zumo 590, ARDcases, LC Enduro footpegs on custom bushes with Wunderlich brake pedal adjuster.
  2. #2
    Join Date
    Sep 2005
    Ashbourne, Derbyshire
    Posts
    2,568
    I have one of the Becker Technik ones, very good it is too
  3. #3
    Join Date
    Jan 2008
    Sevenoaks
    Posts
    564
    Quote Originally Posted by nick.ct View Post
    Thanks Nick
    How rough is the surface that you use it on? I built my garage behind the original garage but retained the original slab. This is none too smooth and I would be using the mover to rotate the bike on this surface prior to backing it into the new garage, putting it back on the mover and shuffling it into a corner.
    Am tempted by the 'wheel upgrade option'.
    Richard
  4. #4
    Join Date
    Sep 2005
    Posts
    2,568
    I think the one with bigger wheels would be better if the floor surface is not so good. The floor in mine is wood and is fairly smooth, so the smaller wheels have not been an issue
  5. #5
    Join Date
    Feb 2017
    The Hague, Holland
    Posts
    271
    there should be some info on here via other threads.....but here's my experience. I have 2 of these:
    https://www.louis-moto.co.uk/artikel...list=348295969
    one for my scooter and the other for my GS. Scooter works fine and is very convenient. Problem is with the GS. Its a hell of a job to get the thing onto its centre stand with the motor mover clearing another 1-2 cm's. Its almost impossible. So my solution is to get the back wheel onto a plank of wood and then lift it onto the mover. Much easier. Once its on it slots away against the back wall of my garage. So perfect.
    I do have a tiled garage floor so its a lot easier. Can imagine if the floor were uneven it would be more of a challenge.
    At this price you cant go wrong either.....
  6. #6
    Join Date
    Jan 2008
    Sevenoaks
    Posts
    564
    There's no difference in wheel size - just the adition of ball bearings and different wheel material.
  7. #7
    Join Date
    Jan 2008
    Sevenoaks
    Posts
    564
    Quote Originally Posted by grantmac View Post
    Thanks Grantmac
    Yep the lift is something that has given me pause for thought. The Becker-Tec has a ground clearance of 7mm whereas the eBay item has a clearence of 25mm so must be much harder to raise the GSA onto. I think that I will go for the Becker unit and add some self levelling compound to the turning area. Picture to follow!
  8. #8
    Join Date
    Feb 2017
    The Hague, Holland
    Posts
    271
    almost gave me a hernia the first time I tried..... but with the simple plank of wood, works a treat.
    What I was really after was a motor mover where I could ride the bike onto, raise it electronically and them move it.....
    Seems this sort of thing doesn't exist. I've seen hydraulic work benches / lifts but then not on wheels......
  9. #9
    Join Date
    Jan 2008
    Sevenoaks
    Posts
    564
    Richard
  10. #10
    Join Date
    Jan 2008
    Sevenoaks
    Posts
    564
    Pictures show approach to new garage - old garage base - and the best I can manage in terms of a close-up of the concrete.
    Attached Images Attached Images
  11. #11
    Join Date
    Feb 2017
    The Hague, Holland
    Posts
    271
    might be a bit rough. Wheels are always small on these things......
  12. #12
    Join Date
    Mar 2002
    Dublin & Andalucia.
    Posts
    4,284
    I use the Becker one on my 1150 Adventure. Fantastic bit of kit and makes moving the bike into awkward spaces in the garage really easy. My garage floor looks smoother than your, so be aware you may need to take it easy on your garage floor.
    2005 SE Adventure 1150.
  13. #13
    Join Date
    Jan 2008
    Sevenoaks
    Posts
    564
    I know. How difficult would it be to use 100 or 150mm wheels?
  14. #14
    Join Date
    Jan 2008
    Sevenoaks
    Posts
    564
    Quote Originally Posted by luke scott View Post
    Thanks Luke. Unfortunately, the turning area is the old garage floor. The floor of my new garage is smooth. Maybe I need a turntable for the old floor and mover for the new floor???
    Or a coat of exterior floor levelling compound on the old garage floor????
    Richard
  15. #15
    Join Date
    Apr 2017
    Manchester UK
    Posts
    1,839
    Is there no room to turn the bike and then push it in reverse into the Garage or am I missing something?
    Caution : May stop suddenly
  16. #16
    Join Date
    Jan 2008
    Sevenoaks
    Posts
    564
    Quote Originally Posted by Andi_archer View Post
    You're not missing anything Andi - apart from the full picture :-)
    The garage is behind my house. The access down the side of the house is, perhaps, 25m in length and at the moment I gingerly paddle the bike that distance past all the usual junk that accumulates alongside a house backwards towards to the garage. I then dismount and wheel it into the garage. There isn't space for me to easily spin the bike around in front of the garage - a task that would have to be done on foot and would involve much backing and filling (I have tried). Thus, I want to be able to ride towards the garage and then spin the bike around easily before wheeling it backwards into the garage. Once in the garage I want to be able to move the bike to a location where it occupies as little space as possible.
    Richard
Posting Permissions
  • You may not post replies
  • You may not edit your posts
